vucko1011
Everything posted by vucko1011
  1. Those are great, but where do I buy those?๐Ÿ˜‚๐Ÿ˜‚
  2. I will not be putting chrome rings because of the shine. I will rather find someone from CZ to buy those masks for me and have them sent to Croatia.
  3. I also found the ebay gauges that you posted. They are just not my taste...
  4. Correct. I am not sure if the recirculation duct lines up, but I have a 3D printer so I will make it work. Favorit does not have any recirculation ducts from factory so I will have to cut out a part from the firewall and probably do some modifications do make the AC fit.
  5. No, the AC controls are integrated in fan/heater controls as you can see.
  6. Golf uses different mount for sure. I used complete Felicia 1.6 subframe so I can use the transmission stabiliser (mount).
  7. Thanks. I have no idea if variable volume compressor would work, there is too little space to fit any bigger compressor. It gets in the way of the compressor/alternator/power steering pump mount itself. The original Felicia AC compressor is Sanden SD7B10 and it is a relatively small compressor. As much as I was using the AC in the felicia for 1 day (bought it and drove it home) the AC is blowing about 2-3ยฐC and I don't see the point of trying to fit a different compressor if this one is doing a good job. Only if you want to decrease the "drag" of the compressor on the engine and the belt to improve fuel efficiency, but I think you would save something like 0.1-0.2L/100km.
  8. Hello, I would like to upgrade my brakes on my Favorit (1994 Silver Line, 1.6 16V AFH/AVY 125hp) Front - I know that I can use Mondeo Mk1 calipers and Mondeo Mk1 256mm discs OR I can use Mondeo Mk1 calipers and Grand Scenic 300mm discs. Rear - I can use Polo 6N2 GTI complete stub axles and everything else. So are there any recommendations for better brakes? I will upgrade to 15 inch alloy wheels with 195/50/R15 tires. Should I upgrade my master brake cylinder? I found some info about Audi 100 master cylinder on Favorit, but I am not sure.
  9. Hello, I would like to buy custom gauge "masks". I found them for sale on tuningsamolepka.cz but they do not ship to Croatia. Where can I buy something similar? Does anyone has any premade masks for the cluster? The pictures I attached are some pictures I found online.
  10. Thanks, I will be a regular member๐Ÿ˜ I will be posting the process of installing of the AC on the Favorit on this thread. And yes, the cat is called Selotejp (Duct tape is the translated name from Croatian, I call him that because he is always by my side and always goes wherever I go hahaha๐Ÿ™‰)
  11. Thats the schematic I was looking for, thank you a million times๐Ÿ˜๐Ÿ˜
  12. Yes, and I also need wiring diagram for whole engine management with AC Great, do you have any schematics?
  13. Hello, I am currently transplanting whole AC system from a Felicia 1.6 1997 to my Favorit 1.6 16V AFH/AVY. I would need a haynes manual with whole engine wiring loom (with AC, obviously). I know I can use the wiring harness from Felicia, but I am just interested in the schematic of the whole 1.6 Magneti Marelli wiring because I would like to change some things in the wiring because some wire are too thin and some are heavily oxidized. And yes, I am a trained car electrician so no worries, I do things properly :)
  2. Tap Permissions โ†’ Notifications.
