![](https://www.briskoda.net/forums/uploads/set_resources_23/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
eager
Finding my way-
Posts
48 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by eager
Code reader/scanner
eager replied to eager's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman
Hi it says these are only compatible from 2001 on petrol engine so probably won't work on mine thanks anyway.Eager. -
Code reader/scanner
Code reader/scanner
Code reader/scanner
@D.FYLAKTOShi I have tested obd port and it has power to it (only 3 wires run into it) I think it's a different shape to the socket of the scanner I tried, will I need a adapter to join them? Thanks.Eager. -
Code reader/scanner
@D.FYLAKTOSI'll check that too thanks. -
Code reader/scanner
@D.FYLAKTOSthanks for the info hopefully will get it sorted 👍 -
Code reader/scanner
@R_U_AFAthanks for that I'm going to have a look at the wiring and see if there is any power to the obd port later I'm sure it lit the scanner up ages ago when I borrowed it but it just said vehicle not responding so I presumed it was probably because of a different language being used by the vehicle.Eager. -
Code reader/scanner
@R_U_AFAhI I see from one of your old posts you have a reader for Felicia which is it and have you had any joy with it please? Eager -
Code reader/scanner
@D.FYLAKTOS yes I think there's a problem with the wires as the obd11/eobd that I tried wouldn't light up even I have a different throttle body from the other pick up I will try fitting that and see how it is as it has different sensors with it, thanks for replying.Eager. -
I think from looking on the internet that I need a obd11 reader for my 2000 Felicia with 1998 engine could anyone please confirm before I buy one thanks.
Code reader/scanner
eager posted a topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman
Can a code reader suitable for the 2000 Skoda pick up with a 1998 engine fitted be bought fairly cheaply?? I have just tried a next peak obd11/eobd that I managed to borrow and it won't even light up. Perhaps there is a problem with the wires.? -
Reset throttle body
Haven't tried yet it will probably go to garage if it carries on. -
Reset throttle body
Reset throttle body
@D.Fylaktos thanks I think I caused this problem by unplugging the connector on top of the throttle housing when car was running to see where the "Morse code" was coming from so perhaps it'll help. Thanks again for all your assistance.Eager. -
Reset throttle body
D. Fylaktos if I use this method to set my throttle will that save me going to the man with the computer? -
Reset throttle body
Thanks again D.Fylaktos I will try this tomorrow, very helpful. -
Felicia pcv valve ?
Thanks D.Fylaktos -
Reset throttle body
Does anyone know if you can set throttle up with a multimeter? -
Crankcase breather pipe
Hi yes Haynes manual is here just looked and there is some kind of filter stuck in the place where the pipe supposed to go,will have a look at trying to remove it and find a piece of pipe to join it . Thanks for the info 👍 -
Felicia pcv valve ?
Thanks D.fylaktos might try this myself 👍
