Everything posted by Rafal78
Help with coding new battery Superb MK III
Thank you π
Hi everyone. Is there anyone in Shrewsbury area that could help with coding new battery? Same typ EFB@ but slightly bigger capacity π. Thanks π
Full Matrix Led headlights on motorway
I tried to speak to Skoda customer service and my local dealer. I explained the problem but they have only one answer : "bring it in, we will run diagnostic". The thing is, there is no fault, headlights not illuminates left side of the road on the motorway but working great otherwise. If no fault found I will be charged for time spent on car plus using diagnostic π¬ never mind my car is still under warranty... Not nice Skoda.. I think it's one of the things we have to get used to... Good, that I don't use Matrix Led on motorway most of the time...
I agree, Matrix on motorways, especially busy motorways is not a great idea. I hardly use Matrix while on the motorway. I'm always worried that I would dazzle oncoming cars. Unless coming back from work at 3 in the morning and motorway is empty. And then it's annoying that. Matrix doesn't work as it should...
I tried that and swapped RHT and it stayed like that but no difference at all. I will update as soon as I will find out something π
I tried on the way to work. Lights are set to RHD/Left hand traffic and no difference. So far it stays, set correctly to Left hand traffic. I guess it must be software issue. I will try to check with Skoda what can be done to put it right π³
Ok, so... I can confirm that I'm not as mentally ill as my wife is claiming... I checked before going to pick two creatures from school up and it was set to RHD. Picked tge creatures up and it was still RHD.. Untill I gone under the bridge, lights came on and I checked then - LHD π¬π€¦. I will have a look when I go to work later in evening. Hopefully it will stay set to RHDπ³ It would be boring if everything is working in the car, right? ππ€£
Yes, RHD but only in my head. I just checked and it is selected LHD in the car π³π¬I could swear I changed it to RHD when came back from France... π© I need to check for few days as I've seen posts of people who had their Superbs changing it every time they lock their cars... Thanks for pointing this outππ Feel stupid now ππ€ͺ
Interesting, need to check this... I might give them a call to double check. Thanks ππ
It's set up to LHD so all good. It could be possibly software as on A and B roads working sweet. I might have to contact info line to make sure and book it in to Skoda. Still under Skoda Aproved warranty till end of March....
I would like to see their face once you put full beam on π I would assumed same as you, there are some funny people on the roads... Seen people driving with full beam on all the time despite others trying to warn them... I guess matrix leds it's great technology but still not perfect...
I have noticed that if I am following the car and hardly can see it's lights, my car will hit full beam but as soon as I will get closer it will dip them. I would say it's good reaction time. Obviously human eye is faster than matrix led system but from far distance it should not blind you in the rear mirror. All depends how it's set in infosystem. You can set reaction time from early to late. Maybe that was the reason kn your case. Yes, car knows when I'm on the motorway. I am using Google Maps but sat nav has new maps and WiFi is always on... My issue is that left side of the road should be illuminated fully but it isn't. I was looking through Internet to find this thread but only found one, where they blaming software for it. I wanted to check if anyone else has similar issue before I will press technical info line on the ceiling π
Ok, Matrix Leds are fantastic. When driving on A or B class roads they working perfect, illuminates both sides of the road and cuts out cars at the front or oncoming traffic. I've never been flashed. When I tried to use them on motorway it's a different story. Right headlamp is illuminating as expected but left one doesn't illuminate side of the road but only gives a lot of light far at the front of the car.. I recently followed Audi Q7 with matrix leds and his headlights gave massive amount of light to the left side, illuminating trees high up... How your matrix lights are behaving on motorway? Normally I'm not using them on motorway as central barrier could stop system recognising oncoming cars and dazzle them, but late at night would be good to have better visability on the left side of the road...
Problems with side mirrors
It's been few days and mirrors are still working as they shouldπWe can close this topic. Once again, thank you for help ππ
I've tried to sprayed the switch on Sunday morning and... it works fineπ It's only been one day but on several trips yesterday and school run today is working good, mirror adjustment works as it should and it dips in reverse every time. I'll give it few days but I think I can comfortably say it's been fixed and I've saved myself at least Β£60 for the diagnostic π Thank you guys for help, it is realy 'easy fix' ππ
Thank you, never tried them but will keep in mindπ
Exactly my thoughts... How can you charge if warranty is valid?? Control switch issues will not show on the computer so it should be invastigation the problem prior repair rather just plug the diagnostic in. As you said, monkey can do it π Checked and most of the local Skoda dealers do this. Plus charge for courtesy car π¬ Fotunatelly I joined a forum of very knowledgeable people so I'm saved πππ
At least I'm not alone with this problem.... I would rather not give it a bangon the door in case I'll brake something else as wellπ¬ I ordered contact cleaner and will have a go soon. Will updateπ
Yes, exactly. I did it several times. It did not resolve the issue so I guess it's the control switchπ
Hi All, thank you for having me here. Recently got my Superb 2.0 TSI SEL. Lovely car. Unfortunately I started to have problem with controlling my mirrors. Sometimes everything works fine, sometimes I can't adjust or fold them manually. Left one would not go down while reversing or goes down and up like crazy. It's quite random and drives me crazy. Car still under warranty but I've been told straight away that if no fault diagnosed by technician they will charge me for diagnostic. I'd rather try to get some help here in case it's an easy fix. I tried reseting mirrors by pressing windows buttons up but no joy. Any ideas, please? Many thanks!
