Lukas_2611
Everything posted by Lukas_2611
  1. So I am still searching and testing.. What I found is that the black panel where the console is mounted on cracks also in the area of the picture.. Right at this spot there is also a white clip behind it which goes into the metal.. its holding the cable harness.. When I push at this spot it crackles.. so for testing in sprayed Krytox (the VW spray, like silicone spray) right there.. on the white harness clip and on the clip of the mounting panel and it was gone.. So the next step is I will fix the white clip with butyl..so it cant move.. The console itself is half quiet now.. the area where the sunglass box is I used felt tape.. no crackling anymore.. the area where the light is still crackles.. I sprayed Krytox on it and waiting now.. testing it the next days..
  2. i have solved this problem by spraying silicone spray all the way above the silver trim. There is a little gap where you can spray in.. it worked great.. the noise is gone since months.. So maybe this helps other people.. Now my roof console (the console with interior light and sunglasstorage) is cracking on rougher roads...didnt find a solution yet but i am investigating.. Maybe somebody with the same problem here?
  3. Hey Buddy! Did you solve the problem? My Console is cracking on rough roads also.. I already took it down and tried to stop it with felt tape... no success till now.. I also wrapped everything with tesa.. didnt help.. Thanks for every help..
  4. @TheUltraRunner I have tried to put some tape behind the door cable, didnt work. While pushing the crackling noise is still there like in the video. I think only a complete sound deadening with alubutyl and foam everywhere can eventuelly solve it. As this is only while pushing I will do it later. In the meanwhile I have recognized another clicking noise while driving on bumpy roads on driver side. Its like a short click an doesnt come always. You mentioned in another thread that you had a noise from this crash clip and solvef it. How did the rattle sounded in your case? In my case it is somehwere in the door area. Maybe the window regulator trim or this crash clip.
  5. My personal guess at this point is that the door cable hits the door card. On the door card are some black melting points with sharp edges from putting it together. So the sound could be the foam from the door cable hitting the plastic. I will try and see if putting some foam in this area of the door card will solve it.
  6. Do you think its the door cable which makes this noise cause its hitting while pushing?
  7. Thank you! Is the door cable not already wrapped in something soft?
  8. I already removed it and in my opion the noise was gone while pushing it not installed to the door. I kind of thought the same, that maybe the part is pushing against the metal or something. Behind this part there should be somewehere the "door opener" cable. I have located the noise coming above the silver trim itself, while pushing in the area in the video. Do you have this noise in your car, as you already put foam everywhere? So maybe something in the area of the pic. Thank you for your help.
  9. But where do i put it? I looks like everything is put together without any chance to seperate 😞 How did you fix the ambient stripe?
  10. Hi guys! It looks like here are some sound deadening pros 🙂 I hope you can help me. I have noticed a strange noise while pushing on my front door card. Does somebody know how i can get this quiet and fixed? My O4 is quite new, actually a 2024 modell, first owner with 59km on it, but its already making noises.. I made a video and uploaded it on youtube.. maybe someone can help me..
