ile7
Everything posted by ile7
  1. @GreggFare https://youtu.be/6FlHM9VZl_s?si=wQcG7M3ktusmqE_3 Check this tutorial
  2. @GreggFare put installed sw train version here for check https://mib-helper.com/ For android auto use quality USB cable, cheap cables can cause similar problem as your.
  3. For TSR, navi is mandatory?
  4. G12/13 pink only! Gas station..
  5. Is there any coding to turn on ambient light with headlights only? It's silly to work during the day but it is what it is...
  6. Yes, you can update to 0480t
  7. Someone mess around with mib before since you doesn't have sw train info. Here you can check possible updates https://mib-helper.com/ According to your post I assume you have p0468t which can be updated to p0480t. https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0468T#details Tutorial how to do it: https://youtu.be/4I5Lnwc1w5c?si=htiM984ox0wxTBQG
  8. 5Q0035840C this is bolero unit, smartlink can be activated, but no navi here
  9. Not only bumps, red light example too I wrote above.. should be deffo around gearbox something
  10. @leolito SS is off, will try in manual mode simulate situation... Could be something around chassis but didn't notice any other noises. Will look a bit further maybe someone has similar "problem"
  11. Don't think calipers are wrong..
  12. @Graham Butcher coasting term was my mistake.. sorry will change the title. What you mean sticking? Clutch or?
  13. Hahah sure thing about radio 🤣 Red light is great example too, while approaching to red which turns to green im D2 full low RPMs speed is under 10 km/h ( gearbox in slowing down "mode" about to stop ) if release brake and instantly move to gas can hear insec grind but if braking and slowly move to gas there is no sound, If let car a bit free roll between braking and accelerating if you know what I mean
  14. FWD only, will try sporty drive, this way gearbox should response faster
  15. Yes had common mechatronic problem with K2 sensor, but that should not be related to grind nose for 1sec in certain situation imo since 1 sec noise been present before mcu repair
  16. @Ootohere Superb 11/2018 2.0 140kw 116k km
  17. @nicknorman Start stop is off
  18. Yes could be normal, just curious if anyone feel the same about certain situation
  19. Ye sorry, coasting was bad term to use.. Rolling in D2, slightly braking to slow down over bump, releasing the brake and start to gas, using 1 foot only ofc. Seems like engine still braking in moment when Im trying to hit gas pedal. If I roll over a bit further and press gas pedal everything is right but im too "slow" for car behind me. Seems It is about timing between engine braking and my foot on gas pedal..
  20. Hello, while approaching to speed bump using brake slightly and rolling over bump in D2, slowly passing the bump and hitting gas normally can feel like grind noise from gearbox? RPMs are cca. 1k or lower sometimes depends how hard foot is on the brake. It is hard to explain this way but seems like brake/acc timing play role here and have got feeling like rpm doesn't match speed in certain situation.. anyone experienced something similar, coasting over speed bumps and hitting gas pedal are best example for me to describe my situation.?
  21. It is dq381, 120k km fluid only change by skoda service book. External filter change is like 10 min job and oem filter cost cca. 30€, so CHANGE IT. Change it sooner like every 50-60k km it is not too expenisve
  22. Sorry for offtopic, interested in front and rear disc size for 2.0 190hp?
  23. Ye sorry updated from 0475
  24. I've done update via SD card normally to 0480T without problems
