Everything posted by TrentBarton
Brake servo vacuum pipe - 6u0611931D
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFor anyone else considering changing the 6u0611931D pipe and check valve... In the end I used a 12mm check valve from carbuilders along with 1m of 13mm vacuum hose and standard clips: https://www.carbuilder.com/products/aluminium-non-return-valve-12mm-2 https://www.carbuilder.com/products/heavy-duty-spring-band-hose-clamp https://www.carbuilder.com/products/vacuum-hose-13mm-id Worked fine. Removing the line from the booster is a bit fiddly without damaging the connection on the booster. I used a heat gun to warm up the old pipe so I could get it off relatively easily. Sadly, the issue remains so presume leak is in the booster itself but it was worth trying for the sake of £20 and 30mins of my time.
Skoda Felicia 1.6 Throttle Position Sensor
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHey @Papez Thank you for checking. I had also gone through my workshop manual and struggled to find any direct electronic link between clutch/ brakes and ecu so good that you have clarified this. It must be based on a load change I suppose. It is very unusual, I have taken the issue to a couple of garages and to some friends who are more knowledgeable about mechanics than I am and have not found an answer yet. Perhaps a strange niggle in the ECU itself? I have cleaned all on my earth connections. I have also replaced the vacuum pipe and check valve to the booster. The issue remains! I have to replace my rear brakes soon anyway so might do the booster at the same time and see if that helps. Failing that, will start looking at ignition system!
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHello all, Back to this again, after trying a few other things to fix idle and rev hang issues, I decided to stick a clamp hose on the brake servo vacuum pipe and see if it made much difference and it did. Without the clamp on, if I am sat at idle and pump the brakes, the revs go up. This does not happen when I clamp the pipe. So perhaps this is the cause of my issues. Either a leak in the pipe or the servo itself. I am going to replace the pipe to start off with. Finding this part now seems to be very difficult. I was planning to just create my own with a vacuum pipe and a non return valve as they are cheap and quickly available. Does anyone have any experience of this? The fitment onto the servo itself looks fiddly.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanNew Lucas throttle body today but still getting intermittent rev hang and slightly odd idle. An interesting part of the rev hang is that it stops the moment I touch the clutch or brakes. My understanding is that when you slowly lift your foot off the accelerator, the TPS sends a signal to the the ECU to gently reduce fuel input so you don't have a sudden jolt effect. However if you touch brakes or clutch to change gear, it drops fuel more rapidly to idle level. However, what I seem to have is that the the ecu is holding the fuel input longer than it should, unless I touch brakes or clutch which instantly overrides and says 'drop fuel now'. Separate to this, I had an issue the other day when it was raining very heavily and the revs went very erratic and the car stalled. This had led me think about possible earth/ connection issues. Decided to sit and look for voltage drop between the -ve on the battery and the engine block to see if there is a bad earth that might be causing a messy signal between the TPS and the ECU. At idle I am getting 0 volts most of the time but very occasional flicks up to 0.2 or 0.3 volts for a second or less every minute or two. I might be grasping at straws now but perhaps this is giving me the problems. So next step, I will get under the car and have a look at the strap from block to chassis. Any advice on known troublesome earth connections and locations would be very much appreciated.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDid a lot of cleaning this morning and put it all back together but sadly, still getting rev hang and a some strange idling. I am going to order a new throttle body today and hope that a new throttle position sensor within the body will solve the problem.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHello @Rsedmonds I've just got back yesterday from working abroad for a couple of weeks. I have the tools, cleaner and new ring next to the car in the garage, ready to give it your treatment this weekend so I will let you know how that goes. Keep me updated on your end. Glad to hear that it is still looking good.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanInteresting. I wonder if the reset process through the OBD has the same effect as the battery reset. Well, I've ordered my seal, thank you for the link. I am abroad for a couple of weeks from Monday but if the seal arrives before then I will give it a go and let you know the results. In case you need it for your one, the throttle body mounting bolt torque wrench settings are 10nm according to Haynes.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThat sounds like a good idea. I've given mine a clean in-situ but not been bold enough to take it off yet and clean properly due to fear that there might be a gasket under there, and in the absence of an off the shelf replacement, might have to make up a new one with gasket paper. However, after some more research and speaking to a few friends with old VWs, I am pretty sure it is just the ring seal described in the Haynes manual above so time to be brave, take it off and give it a really good clean as you say, hope the ring seal doesn't disintegrate in the process.
Wheel arch rust repair - first time!
TrentBarton replied to TonyW1967's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanNice work, inspired to give mine a go now
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSorry to hear that @Rsedmonds . Your big discovery led me to looking at my negative connections to the block but they were all in good condition so no quick fixes for me either. Do you really think the ECU will need a reset with a new throttle body? My manual does not suggest it does. See Section 6 below. I thought just a battery disconnect after replacement would do it (see the smaller screengrab below).
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHello all, Thank you @Papez for all the information. I have the same issue as @Rsedmonds with no diagnostics, see here. Perhaps also related to immobilizer, interesting to read about this. Glad you got your sorted @Rsedmonds . I'm still struggling with mine, seems tricky to get a clear method of diagnosing using the multimeter. Tempted to just put a new throttle body on and hope for the best unless anyone has any other ideas? There's a few brands out there for 030 133 064 D. - £50 - Allcarb, Apriciter - £75 - Lucas, Intermotor, Vika, Lemark - £120 - Febi Anyone got experience with any of these and how they have found them? From what I can tell, there is no gasket, just a ring seal? Correct?
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAh nice one. Can you put a link to that youtube video so I can catch up?
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHey @Rsedmonds . Not at all, all the help we can get here is helpful. Sounds like you have a very similar problem to me. Mine started in the way you describe and has recently developed into this intermittent 'rev hang' thing. Pondering whether to get a replacement throttle body and just give it a go if there isn't a clear diagnostic pathway.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes that is all true. But I was wondering if anyone has had experience doing the pin test on the throttle position sensor, if my diagnosis is correct, and experience replacing the body.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHey @Thefeliciahacker , that's right. 1.6l 2000.
OBD Tool - to buy or not to buy?
TrentBarton replied to TonyW1967's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThat's strange. I also tried it with a friend's VAG COM OBD2 cable and got the same result. Airbags and ABS but no engine data. Not quite sure whether to spend money on different hardware or whether it is an issue with the engine not giving data.
Hello all, I have been doing a lot of reading of old posts. I have an issue of 'rev hang' where the revs do not drop once I release the accelerator pedal. I also have strange revs at idle where it can sit at 1k or 1.5k or even 2k sometimes, until I turn the engine off and on again and it seems to reset back to its normal at around 0.8k. At first I thought it was perhaps a vacuum leek but I have smoke tested and found none. Today I used a multimeter on the TPS pins to read the resistance between pin 1 and pin 2 whilst moving the throttle body and found near 0 ohms in every position. This suggests to me that the sensor now is telling the ECU that the throttle is idling all of the time. Is my interpretation correct? Is it time for a new throttle body? In which case, does anyone have any recommendations for a replacement for 030 133 064 D? Thank you
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFair comment @D.FYLAKTOS . I decided to buy some money and spend some effort on a 2nd hand smoke machine instead and tested all the intake system and found it to be tight. Worth £25 and an hour of my time. Now I have some more questions but for another thread!
TrentBarton replied to TonyW1967's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHey @Thefeliciahacker . Have you ever had an issue with this combination where VCDS Lite gives you Airbags, ABS but no Engine data? Is it because I have the wrong cable? I have a VAG COM KKL OBD2. Can you recommend a cable if that is the wrong one?
Hello all, Got a suspected vacuum leak in the brake system. Wanted to start with the most likely culprit, the vacuum pipe with the inbuilt check valve. Seems impossible to find a replacement. Has anyone managed to find one recently? Or has anyone improvised with vacuum line and a check valve from something else? Thanks
Felicia 5th Gear Nut Repair + Diagnosis
These photos don't exist anywhere anymore do they? I have this job to do this weekend.
Felicia 1.6 OBD and Emissions
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanJust to finish off this thread. I never managed to find an OBD that would communicate with the ECU so took a gamble on a Lambda and it worked a treat. Emissions down from 6% to about 0.2% instantly so there you go! Thank you to everyone for your ideas and help.
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHey @D.FYLAKTOS . That is massively helpful, thank you. I am trying a new Lambda today and hoping for the best. I had wanted to get diagnostics on it first to make sure I am not wasting money but I was struggling. I have read all of the posts you have put through. Is the summary that for a 2000 1.6 Felicia, it has to be OBD1 or OBD11 with K-Line or VAGCOM but not OBD2?
TrentBarton replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanMy understand is that you should be able to get ECU faults and emissions related codes/ data using the VAG tools but would be interested to hear anyone's advice on that? Service history of the car is very good. Never missed an annual service since new. It has done about 10k this year where it has had a new fuel filter, oil change, timing belt, water pump, temperature sensor and a few non engine related things. I have noticed on this MOT history before that the car has had high emissions failures in it's past. I also notice that the engine management light doesn't come on when it should. I am wondering if someone has played with the system to prevent the light coming on (it is an MOT fail in the UK) and this is also stopped the communication to the OBD tools. CO is currently 6% at idle so high!
Hello, I have a Felicia 1.6 (2000). It is in nice condition and well looked after car with 70k miles. This is the first time I have tried to put it through it's MOT test and it has failed on emissions and would appear to be running slightly rich, though it runs smoothly idles well. We have tried to connect the OBD but cannot get any useful information. We have tried two different OBD devices with the same result. The OBD gets power and displays some information such as the ABS system but it doesn't give any information on the engine management. Does anyone know why this can happen? It would be useful to see what the ECU says before spending money on potential fixes.
