Everything posted by zer081
Stop/Start issue / Battery Question
When I got the battery tested it was down to 71% of it's performance when new. I believe 70% is when a battery is classed as "dead" / in need of a replacement. The dealership initially said that batteries are not covered under warranty, but after some pushing they agreed to replace it. This was a couple of months ago now and since the new battery was installed stop start has worked flawlessly and I have not seen a return of that particular message.
Quick end of the week update.... The dealership initially said "the battery is not covered under the warranty, but I will speak to the head of business to see what we can do". I have subsequently had an email from them to say the head of business has authorised the replacement of the battery at no charge to myself. I am going to ignore that it is worded like it's them doing me a favour and take this as a win as it could have been so much more painful with them. Once again, thanks to all the people offering advice here, it helped me get to where I am now! Finally, after reading all these posts about people not taking care of their batteries as an ongoing concern, can you recommend anything I should be doing once the new one is fitted to ensure it's kept as good as it can be? Thanks again everyone (and happy weekend too!)
I could not find the option to edit the above post, but Pete has confirmed that the battery appears to be the original battery.
Thanks for the reply, I will try and add a bit more info based on what you have said (although I am far from a car expert and a bit confused by some of the points you mentioned here). Car Details as follows: - Year - 2019 Model - Kamiq Trim - SE L Engine size - 999cc Fuel - Petrol The guy at the garage seemed to think that it was probably the original battery from what he could tell, but I guess you can never 100% be sure from a visual look. If I am understanding your question correctly, when they did the scan, they looked at the values on the battery label and entered those as the parameters before the test started, rather than looking at what had been coded for the battery. I will send Pete a message to see if he would be able to assist and will post back if he is kind enough to assist. I am wondering if at this stage, with all the faffing round it it's just worth cutting my losses now with the dealership and replace the battery myself as the percentages here seem to imply its closer to being a "bad" battery than a good battery now.
Morning All, It's been a while since I posted, so I thought I would update on the latest state of play with the stop/start issues. After a few weeks of waiting, the car finally went back in last week to have a few things sorted (which to be fair, were sorted out no problems), however, once again, they said they could not find any fault with the battery or stop/start as no errors were being logged. They apparently put it on charge whilst it was in as well (not sure how long they had it on charge, as due to a shortage of staff, they had the car for going on 1 week), upon collection, the stop/start seemed to work perfectly for a few days, until last Friday. On the way home from work, I ended up in stop/start traffic for about 20 mins and after 7/8 interventions of stop/start the normal "power consumption high" message returned and stop/start did not kick in again for the rest of the journey home. Saturday, I headed down Altrincham way (100mile round trip, 95% motorway) and the same "power consumption high" message persisted all through the journey and stop/start never kicked in. Sunday/Monday this week stop/start was intermittently working along side regular "power consumption high" messages, so I stopped off at the local garage, who have always done service/mot on my previous cars for them to do a proper battery test. Attached are the results of the check and as far as I can tell from reading them, what he said and what Dr. Google says (although I take what he says with a pinch of salt generally), although the battery states "good", it is borderline and 1 or 2% lower and the reading would be a flat out Low. This test was performed with a "professional" external battery tester with the battery disconnected from the car after a period of 20-30 minutes parked up. I also managed to get a pic of the full battery label when the battery was disconnected as well should that be more helpful that the last image I posted. All indications are that the battery is the original one. Hopefully with this evidence I may be able to go back to the dealership and force them into changing the battery under the 12 month warranty the car came with (fingers crossed!)
Skoda Kamiq stop/start fault and associated screen fault
I think that is just showing that the break pedal is being pressed. If I remember correctly, it also shows the indicators flashing when on that screen - possibly other things too. I guess that screen is a "live view" of the car.
I found that when comparing the plug-in with multimeter direct to the battery, the values were not a million miles off. With what you have said above now though, I'm not sure what the next point of call should be, the dealership said battery was fine as did Halfords and I suspect all the dealership will again say is battery is ok, we can't fault it.
Thought i'd give a quick update as it's been a few days since I posted. With the second external battery charger I used (which I know was working as it was used the previous day to charge a different battery - not fitted to a car mind - and reported "green-fully charged on that battery), I left it on overnight and it charged the battery to 12.7v*, but never recorded the battery as being full, as the indicator light remained on amber. Arrival at work (after 30-ish mins travel) battery remained at 12.7v*. After an 8 hour day, checked battery before turning engine on and battery reporting as 12v* Arrived home and battery reading 11.9v* However, each day this week, the temperature has been a lot higher and as a result, every day this week, the stop/start functionality has worked perfectly as expected. So, maybe there was never really an issue with the battery and it was, as implied by the dealership down to temperatures. One to keep an eye on I guess but for the time being, I am not going to think too much more about it and see how it goes. Thanks once again for everyone's advice though, very much appreciated. *(voltages checked with plug-in tester into cigarette lighter socket.)
Stranger and stranger with this now... Checked the reading before I set off from work at 16:30 and the reading was 11.9 (exactly the same as it was this morning). All the way home , stop/start functionality was available and working ! So I'm even more confused now. I've also found that the battery charger I posted earlier is faulty and not charging correctly (as confirmed by checking it in a fully charged battery) so I've got another one to try this evening that I know is working. It may not even be a battery issue after all this considering it was working again this afternoon and maybe it is just so so with the temperature at the moment....who knows at this stage (well I certainly don't!) Couple of photos as well of how the terminals look on the battery.
The figures quoted were taken using the plug-in 12 checker (again - i know not totally accurate, but better than nothing at the moment) The battery was attempted to be charged with an external battery charger (mains powered) (image of that attached). I've not checked the figures whilst driving with the plugin digital thing, just before turning the engine on and after it was turned on. I don't want to go against what you have said, but I am not entirely sure what good it would do putting it back on charge again this evening, as I was in and out during the period of charge from Sat night to yesterday tea time and the voltage did not seem to change for hours once it got to 12.2v. I did not look in detail at the connections, but it's one more thing I can check this evening. The Kamiq does not appear to be listed on that link currently, would it be safe to assume its the same as one of the other makes on there?
The reading this morning was taken after I locked (and left the car alone) at 17:30 ISH last night, so plenty of time for the vehicle to have shut down.
Me Again! Quick update from over the weekend.... I popped the battery charger on over night from about 10pm on Saturday night, checked it periodically through Sunday and the voltage got up to 12.2 after the best part of 18 hours charging (and never reported that it was full). So, after that period I ended up taking it off charge and immediately, the volts went down to 12v. Checked again this morning (around 7:20) before staring it up and voltage down to 11.9v Drove to work and checked it again as I got out of the car (7:55) and the voltage was 12.7 All through this journey the infotainment system reported "power consumption too high" and stop/start failed to engage once. I am guessing that the alternator is working ok as the battery is charging on the journey to work, but 11.9 seems to be quite (very?) low.
Thanks again for all the new info, people here are great, especially to new people who probably ask age old question! I did check it again this.morning and it's still showing 11.9 with the 'plugin' volt reader and slightly higher with a volt meter directly on the battery. I've loaned a battery charger off my dad and I'll pop that on overnight tonight to see how theyit as it did indicate it needed a charge. I didn't see much identifying info on the battery to be honest, but took a couple of photos anyway of what I saw, maybe they are what you needed, apologies (Also, stop start did seem to work again today more regularly after the day got warmer, so who knows what's going on!)
Well, Halfords have said there is no problem with the battery and it's currently is as it should be according to their voltage meter. I'm going to check it again in the morning though after an evening of not being used and see how it goes. Interestingly though, I did a factory reset today and since then, the stop start has worked each and every time I've stopped, which it has never done before. Maybe when it was in the dealers they did some sort of software reset / code update and now after a factory reset on the infotainment screen it's picked up something that has allowed the car to correct read everything. I did forget to photograph the battery though today, so I'll ensure I do that tomorrow and post the image here.
I'll take a photo later when the battery check takes place, but the other info... It's a manual, petrol version and it's the SE-L trim model.
Is there any way to know if the battery is coded correctly to the car or is it a dealer only thing? Also, how would I know if it's the correct size (and also of it's the original one too I guess). I know the internet is there, but there is so much misinformation there it's hard to know what is correct and what isn't. Thanks again too everyone who has helped here so far!
Thanks for the detailed reply above, much appreciated and lots to digest. Ive just booked myself onto a free battery check at Halfords for later today, so at least I can get an "official" external review, then I'll leave the multimeter test till tomorrow morning. Good point you raised about why they did not charge it overnight as they had it for 2 days dut to looking at a couple of other issues (hindsight and all that eh!). They initially said to me about having too much plugged in / using aircon (never turned it on - it's winter!) / using electric seat heaters (not an option on my car), so im already primed for them to not want to sort this. I know most people will say they hate Stop/Start but for me it's the principle of I've paid for these features, they should work.
Thanks for the information guys. Going to check with a volt meter later today as well. If the battery does end up being around 11.9, do you think that's a valid reason for me to take it back to them and get them to replace it (as it's appearing to affect stop/start), as I'm less than 3 months into the 1 year warranty.
Sorry, just to explain a bit more here as I don't think I explained correctly. I was going to attach an external battery charger to the battery to try to fully charge it to see if that makes the stop/start any more efficient. So I guess I should have said "can this be done without disconnecting the battery" then (if I had to disconnect the battery) "what effect would this have on the car. I am not sure of the age of the battery, as I bought the car 2nd hand (it's a 69-plate Kamiq). I attached one of those cigarette lighter port battery checkers in this morning before starting the car (I know they are not that accurate but a starting point...) The values returned were:- Engine off = 11.9 Engine on after a few seconds = 14.3 Thanks!
Hi, Car has just come back from the dealership after having a few issues looked at, including the stop/start function only working about 10% of the time. The message I always see is "Power consumption too high". I have nothing plugged in, temperature set to 16 degrees etc etc (so nothing that should cause high power drain). They have said there is nothing wrong with the battery and to keep an eye on it, so it feels like a bit of a fob off really. Onto my question (after that back story) - I'm thinking of putting an external battery charger on the battery to see if I can charge it separately to normal "running charge". If I was to disconnect the battery for a night, would it cause me to lose anything I can't set up again myself? I'm still convinced the battery is the problem which is why I want to do my own investigation before going back to them with some facts. So any advice on what will happen with a disconnected battery or people's history with start/stop greatfully received. Thanks in advance .
Boot Torch not working?
My drive to work each and every day is around 30mins (each way) so that's not a small journey I'd say. Yesterday also I drove 2 hours to my destination (none stop) and the same home again and that made no change, so I don't think its related to not having enough time to charge. It's either a faulty connection on the car or a faulty torch I think... With that said though, I'll also make sure it's firmly in place ( I think I have pushed it in place already but I'll be 100% sure when I check again tomorrow).
I haven't taken a close enough look at the working of it to be totally honest, but I'll check when I go in there tomorrow.
Yep, looks like there how it's supposed to work (also what is stated in the user manual, which I'm not sure why I didn't check!) So, I'll add that to my list of things to fix when I goes back in on a month or so.
Nope, if I manually turn it on, then close the boot and open it again, it's still on
I've only had the car 2 or so weeks and was trying to get a consensus of if it should come on or not before raising it with the dealership - they said no it should not come on but others say it should and videos seem to imply it should too. So no, I have not checked that yet, but I would have thought it it was not having power, it would not charge and would not come on at all...
