Everything posted by whippersnapper
Dash warning lights
Also amazed at your fuel economy (6.5l/100km) despite slow speeds and then realised that your car can’t be an RS as I get nowhere near that unless I was cruising on the open road!
2024 Facelift Octavia Dash Rattle
My FL is as quiet as a mouse rattle wise and long may it stay so.
Dash warning lights
Yes normal. Just telling you the battery is being discharged.
Centre Caps for 2025 VRS
I doubt it, they’d look weird if there wasn’t some fancy floating way to keep them oriented the right way
Not sure exactly what you mean. Mine has the Skoda logo on them
Aftermarket wheel for FL Octavia RS
oh interesting, I assumed the Elias was standard, they were for me. Lighter or heavier will still impact the suspension.
I’m interested to hear what others say. I would guess it would void the warranty but depends on the wording and the laws of where you live. Most countries have consumer law that protects you beyond the warranty. I would expect bigger wheels to be heavier and therefore the suspension tune will be out due to the change in the sprung to unsprung mass ratio.
Please Help
Depends if you worry about things that aren’t important. There is a reason the exhaust goes outside the the car rather than into the cabin.
Please Help
The catalytic converter converts CO to CO2. Almost impossible to have an issue inside the car without a serious malfunction.
2025 Skoda Octavia: Can the Coasting/Neutral Roll Feature Be Disabled?
I wouldn’t worry about start stop despite various videos doing the rounds warning about it. The cars are designed for it and the system is very sophisticated. For example it will even stop the engine with one cylinder at TDC so that re-start is essentially instantaneous.
Maybe this is something only for non RS models. Pretty sure mine will only coast in ECO mode. Never had the engine turn off doing down a hill or have the gearbox go into neutral in the same circumstance.
- Dynamic rear indicators on Octavia mk4
Dead Battery-VRS mk 4.5
No issues. I’m not saying stop start is the cause it was the symptom that the battery was not okay as the car won’t use stop start if the battery voltage is too low. I simply must have had a bad battery from new. It happens. I think this is largely bunk. Stop start probably doesn’t provide real world fuel savings that it does in the official fuel economy testing but it won’t produce accelerated bearing wear. There is no evidence of such a thing despite how long the tech has been in place and there are plenty of other failings of modern VAG and other manufacturers
Yes mine was replaced at about 6 months as noted in other threads you can search. Hint was the auto start stop hardly ever operated and some very occasional weird error lights which led me to the dealer to check it and they replaced it. Problem solved.
Please Help
No idea but he first thing is try is leaving your seatbelt on. The warning is clearly designed to warn about leaving the car with the engine still running.
iv battery-only range
Also remember the hybrid is quite a bit heavier than the ice car too so another reason for plenty of air pressure
It will make a difference.
Must have different tyres than me then. Normally pressures are but in a manual but on the sticker in the four frame or similar. Definitely 39 for the 225/40 19s
Other thoughts. The 60km will be city too not any open road stuff. Also not sure what wheels and tyres are on the IV but my ICE RS the tyre pressure is 39psi not 33.
60km is perfection. Anything other than about 20C ambient temperature when driving, gradient, rain, air con, heated seats etc will all detract from that. Tyre pressure is important too.
Love my new wheels
19” wheels are standard at least in NZ. In comfort mode it’s okay on bad road surfaces
- Can I reset the Battery Management System (BMS) MK4.5
Battery problem
Identical to mine then. It’s been perfect since.
