Everything posted by whippersnapper
Octavia vRS FL first impressions
- Octavia MK4 Stop/Start Settings
looks great although the lighting and photos look far higher quality than the first ones!
New Zealand. There are no features like the app or driver profiles or ota updates
Sorry can’t help, in my market there is no OTA
A few errors this morning
Mine cranked fine too.
I have H10 and 2565 software. Never had an issue with a drop out on the Canton audio
Nice.
Fuel mapping issue??
Whoops, what an idiot, I keep thinking in terms of the 4.5 which are all DSG 🙃
Has the DSG oil been serviced, sound more like jerky shifting from what you described that rough engine running. if definitely should be smooth, my car feels like an auto just driving around in normal mode. To check the gearbox you could put the car in eco and then use the toggle to put the box in sport mode. If you get the same symptoms despite the eco map (and I assume the fuelling isn’t different in eco it’s just going to be the throttle mapping and gearbox shift points) then it suggests it’s the gearbox
I got various ADAS errors and start stop not working very often. Needed a new battery at 6 months old
I’d immediately suspect the battery. Another thing to notice is whether the stop start mysteriously doesn’t happen anymore or only very rarely.
Poor Headlights
I find the new 36 element matrix lights on the 4.5 awesome
- New car
Just how reliable is the Mk iv ? Would you avoid.
The mark4 and to be honest most VAG products of the same time seemed to be plagued with software issues. I’d imagine any car you’d buy now that has had all the updates would be ok. However the 4.5 is a big step forward in many areas and seems to be pretty right from an infotainment perspective out of the box. Modern cars for good or bad are largely software defined vehicles so this is a very important point.
Full Manual mode for the Gearbox?
This is normal behaviour, if you use a paddle the gearbox responds and after awhile goes back to the automatic setting, it’s for knocking down a gear to pass someone for example. If you use sport mode overall or select sport for the gearbox with the toggle then using a paddle will switch to manual and stay there until you toggle back out of it or hold the up paddle in which does the same thing (cycles from manual to sport to drive)
Octavia 2025 Laura assistant
I have it but u think I’ve tried it a couple of times but never use it. Talking to my car isn’t a thing I find the need to do save for the occasional Siri command mostly for texting or calling someone or navigating somewhere
4.5 Tyre pressues
Yes I don’t like Bridgestones much either and most cars here (NZ) have them so in guess I’m lucky. Didn’t know much about the Goodyears but they are up there with PS4s and feel like that too. Although I’ll probably switch to Michelins anyway they are my preferred brand for 2 and 4 wheels.
DCC Damper Fault
Just info in case it happens to anyone else. My 9 month old Mark 4.5 Octavia RS wagon started flashing up a Damper Fault recently with each engine start along with the damper logo and warning triangle. The manual said off to the dealer so I sent it in yesterday and had a Scala 85kW loaner (very gutless and way too much turbo lag off the bottom end before it gets going) for the day. The issue turned out to be a speed sensor that had become detached from the system. Hopefully that is that and onwards we go. This is unfortunately the second warranty issue in 9 months (first was battery replacement). It is reinforcing the view that VAG vehicles really are something you only want with a warranty.
4.5 Tyre pressues
I’m running 39. My last car had 225/45 18s and I ran 37-38. I have tried a few psi less and it just seemed to have more movement. I don’t find the ride bad at 39 although I have DCC. My oem tyres are Goodyear Eagle F1 Supersports. Most people underinflate their tyres which leads to less grip, less fuel efficiency and more wear.
No idea but on mine a touch does Laura but holding it triggers Siri
Dash warning lights
Also amazed at your fuel economy (6.5l/100km) despite slow speeds and then realised that your car can’t be an RS as I get nowhere near that unless I was cruising on the open road!
2024 Facelift Octavia Dash Rattle
My FL is as quiet as a mouse rattle wise and long may it stay so.
Dash warning lights
Yes normal. Just telling you the battery is being discharged.
Centre Caps for 2025 VRS
