Everything posted by EduardDo
PDF with coding and adaptation
Hello everyone, I found this PDF containing various modifications and adaptations for the Golf 8, and it looks like many of them also apply to the Skoda Octavia IV pre-facelift (Non-FL), based on my own testing. So far, I have only tested the adaptations that can be performed without SFD authorization. Unfortunately, I currently don't have a working method to unlock SFD. I can successfully read the Challenge Token and manually enter the Release Token, but I don't have a way to calculate/generate the corresponding Release Token. i also have some of the software releases : 1941, 1969 ,1985, 1989 If anyone can help with that part, I would also be happy to test additional adaptations and features on my Octavia IV and share the results with the community. Any help would be greatly appreciated! Codierliste Golf 8 EN.pdf
- OBD2 Tool
Edit Sound settings - dataset export (OBDeleven, Car Scanner Pro?)
I'm pretty late into the conversation but some guys on YouTube used a full DSP to flatten the sound and then feeding the signal into another amplifier also change it afterwards how they like, but it's pretty expensive ,about 600 euros the DSP
- OBD2 Tool
- Retrofit 13" Enyaq Display to Octavia Mk4
New godies for the car
nevermind the module worked, did not fully placed the wires first time , and works perfect 🍻
It's the same module as mine, maybe it wasn't fully plugged? So the car faced a lot of error after I've installed it, and I tried to start the motor , started for 2 seconds then died, after that it would not even crank , of course after I reverted it back the car went fine, had a engine light but I just had to delete the error codes, a lot of no communication codes
The car won't start with the module🤣🤣
Purchased a few goodies for the car Engine start stop cover Auto start stop off Black emblem Will get back how the auto start stop off work 🥳
Dash Virtualcockpit posible Googlmaps
From all the research I have done it's not posibile yet on Mk4 , on Mk3 that was possible with a custom modification to the central infotainment
- 2021 octavia upgrade interior boot lights to led
Menu 5F lots of display content to activate - anyone tryed?
Hello here is my map of the menu 5F, i see that there are a lot of menu options that can be activated, and from my research is basically the menu in the infotainment, has anyone tried them or something? Ex. adpmap-5F-5E3-035-816-F_TMBJJ9NX2MY009396-20251006-1824.CSV
Manuals for Skoda Octavia 4
Manuals for Skoda Octavia 4 : Avalabile for 3 days https://we.tl/t-TID7E3Cpca?utm_campaign=TRN_TDL_05&utm_source=sendgrid&utm_medium=email&trk=TRN_TDL_05
- Skoda Octavia 4 - Add classic subwoofer into the trunk
Another infotainment issue
https://www.drive2.ru/l/714438467546790126/?fbclid=IwdGRjcANB2hFjbGNrA0HaD2V4dG4DYWVtAjExAAEevBNX94qCMVJrZvzDfCBdng4FHIpI9JE7YFFUHtmhUMhH9-ViatTkyyKdu-Q_aem_B5zaVBKAq3HJAGPDClP0RA Maybe this will help someone, some guys said that there are some vapors on the volume control slider , and that causes issues where the infotainment restarts or changes the volume
Remote Start Key Fob
Hello did you found a way?
- Cheap and easy under seat storage solution
- Blind spot assist retrofit
So sad to learn you can't diy your car anymore, my car has SFD 1 and even with obdeleven I don't know if I can unlock itt and the swap to vcds to do the adaptations The vcds I have is a clone one bought it with 40 Euros , but another 150 Euros for obdeleven just to unlock sfd once ?? It's a lot
