Everything posted by EduardDo
New software available version 1989
The changelog of the software version?
Any more news? Everything is stable? Did it fix the issues with Android auto where it does not display the yt album cover or Smth like that?
Skoda Octavia 4 - Add classic subwoofer into the trunk
I’ve started installing a classic subwoofer in my car and wanted to share how I routed the wiring: Power cable (VCC): I ran it along the left-side plastic trim, under the rear bench. To get into the engine bay, you need to remove the plastic cover near the hood release handle. Behind it, there’s a rubber grommet in the firewall that becomes easy to spot once you peel back a bit of the foam. That’s the perfect spot to pass the cable through. Ground (GND): In the trunk, on the left side, there’s a cover with an 8mm threaded bolt – a great grounding point. I also had to remove the battery to pull the power cable upwards. The battery is held down by a bracket; once that’s off, you can slide the battery forward to release it from its lock. To feed the wires more easily, I used a fish tape (the kind electricians use to pull wires through conduits). That saved me a lot of time and effort. Helpful video : https://m.youtube.com/watch?si=anaXbne7mRiMxD2K&v=BD1Lb-lvHWo&feature=youtu.be P.s
Deactivate star stop, turn of the climate , roll the window ( for fresh air ), keep motor on , you will stay there for a solid 30 minutes , I don't think would be a problem but myself I did not even opened the door , just stay put
Keep the motor turned on !, the last thing you want is your battery to fail
Give us the updates 😁 from 1806 to 1941 found a lot of differencees
This is the exact zip file that you've updated the car with?
the download files look ok, not yet uploaded to the car
Update To Infotainment Version 1985 - Download Link and Guide
Maybe upload it on Google drive and share the link ?, what did you tonice is different?
- Retrofit 13" Enyaq Display to Octavia Mk4
- Skoda Octavia 4 - Add classic subwoofer into the trunk
Update mine from 1806 to 1941 no problems, don't know if I should update to 1985, heard people got problems with AA
Repair manual/Workshop manual.
Hello, could i also get for the ventilation system :( , my flap is making a weird noise whenever it changes the direction of air , i cannot PM (new user)
did you copy as well the 3rd file with 0 bytes?
Hello everyone, this is my first post. I recently got a Skoda Octavia 4 non facelift and besides some basic VCDS adaptations (still figuring out how to unlock SFD), my main focus is upgrading the audio system with a classic subwoofer in the trunk—I don’t have the Canton setup. I’ve already found the speaker schematics and bought a high-low adapter with remote-on signal. What’s giving me trouble now are the power wires. Does anyone have a picture or some info on how to properly route a wire from the battery terminal to the trunk? The part I’m most unsure about is getting through the engine firewall and knowing what needs to be removed or disassembled in that area. Also, I found out that on the Octavia 3 there was a setting in unit 5F - Long Coding - Byte 12 - Activate Bit 2 (Sound System Internal Individual) to improve sound adjustment for non-Canton systems. Does anyone know if this option still exists on the Octavia 4 (non-facelift)?
