Everything posted by YMe
Superb Mk iv Hybrid 12 volt battery.
Hahaha! I just realised after making this post that this is the Superb iv forum as iv is Roman Numerals so Mk 4 it is. Nothing beats making a **** of yourself in public. My question above still stands though.
I know this is the wrong forum but there is not yet a Superb iv forum and I don't know how to create one. My question is when I charge my Superb hybrid battery, is the 12 volt battery also charged?
- Start stop
Changing a s/s battery?
i replaced this exact EFB battery on my 2017 Octavia within the last few weeks. The Octavia I had before my current model had an AGM battery. I imagine the EFB battery is now fitted as a cheaper alternative. The battery I fitted was an AGM and I have VCDS so updated the battery information using the guide above. I can recommend it except VCDS wouldn't accept the serial number in the way illustrated. I removed the "/" in the date and left spaces and VCDS was happy.
EPC Warning light
I have replaced the battery as the resting voltage was hovering just under 12.5 and it is 5½ years old so not at its best. Travelled several hundreds of miles towing since and problem <so far> has not reappeared.
Varta AGM battery serial number
That guide is excellent with one exception. My VCDS wouldn't accept the date in the format shown. It was happy though if I entered the date without the dashes and left a space instead.
EPC Warning light
I wondering if the extra load of the caravan electrics on top of a failing battery may have something to do with this as driving 100 or so miles, without the caravan, since clearing the faults, nothing has re-occurred.
EPC Warning light
Battery fully charged Saturday 8th May. Didn't check the voltage after charging. Ctec charger until green light lit up. After a 20 mile run in two stages of 10 miles out, 2 hours off, and 10 miles back, on Sunday, tested battery today and it reads 12.4 volts. Battery is over 5 years old is it failing?
EPC Warning light
The lighting fault codes I ignore as there is nowt wrong with the lights and never has been. Funny that it has disappeared now though.
EPC Warning light
I have cleared all the faults and been for a short test drive. Another auto scan showed all controllers "no faults found." I'm not unduly bothered about the heated steering wheel fault as it is an old one and the heated steering wheel gets warm when I want it to and, to me. that is all I am looking for. Don't pretend to understand the mis-fire and Westgate stuck open stuck closed though. This is the first time I have done an auto scan since I did the tweaks in my signature and it is the first time I have seen my auto scan with no faults showing.
EPC Warning light
Carried out a full Auto Scan and I have come up with this:- Saturday,08,April,2023,18:23:42:02159 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4 Data version: 20230228 DS346.1 www.Ross-Tech.com VIN: XXXXXXXXXXXXXXXX License Plate:XXXXXXX Mileage: 43704km-27156mi Repair Order: Chassis Type: NE-SK37 (3Q0) Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 4B 52 5F 69 6C D6 D7 VIN: XXXXXXXXXXXXXXXXX Mileage: 43704km-27156miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb Part No SW: 05E 906 018 A HW: 05E 907 309 Component: R4 1.5l TFS H22 4937 Revision: 81H22000 CVN: F7D9BFAF Coding: 012500322474050800000000000000000000000000000000 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_ECM15TFS01105E906018A 003006 ROD: EV_ECM15TFS01105E906018A_003_AU37.rod VCID: 231214613B557EE2321-8076 VINID: 91D4928877951DA0011C608200072709FF 4 Faults Found: 17159 - Databus U1123 00 [032] - Received Error Message Intermittent - Not Confirmed - Tested Since Memory Clear 10591 - Cylinder 1 P0301 00 [096] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear 37663 - Turbocharger/Supercharger Wastegate 1 P25B4 00 [032] - Stuck Closed Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 43503 km Date: 2023.04.06 Time: 11:06:57 Engine RPM: 1091.50 /min Normed load value: 2.7 % Vehicle speed: 19 km/h Coolant temperature: 105 °C Intake air temperature: 23 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.740 V Unlearning counter according OBD: 37 Charge pressure actuator: specified position: 29.50 % Bypass valve f high press turboch turbine inlet: actual value: 49.98 % Charge pressure actuator: adaptation for lower stop: 2884.4 mV Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 51 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 5 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 7 Bypass valve for high press turboch turbine inlet: uncond volt: 1335.6 mV 37664 - Turbocharger/Supercharger Wastegate 1 P25B3 00 [032] - Stuck Open Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 43502 km Date: 2023.04.06 Time: 11:04:41 Engine RPM: 1735.50 /min Normed load value: 1.6 % Vehicle speed: 61 km/h Coolant temperature: 95 °C Intake air temperature: 24 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.720 V Unlearning counter according OBD: 37 Charge pressure actuator: specified position: 29.50 % Bypass valve f high press turboch turbine inlet: actual value: 49.96 % Charge pressure actuator: adaptation for lower stop: 2884.4 mV Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 80 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 5 Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 7 Bypass valve for high press turboch turbine inlet: uncond volt: 1335.2 mV Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 049 G HW: 0AM 927 769 E Component: GSG DQ200G2_M H05 1005 Revision: 00005026 Serial number: CU501709166728 CVN: 6F1C2C4E Coding: 0014 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021_VW26.rod VCID: 41DEBEE9C1094CF240D-8014 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD Component: ESC H25 0513 Revision: 00000000 Serial number: 62617000000039 Coding: 24078A91242721724079060240C3242451248402600224723621F070C002430000000012121212B8586C384E4484EE Shop #: WSC 73430 031 00000 ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod VCID: 77AA1031DF4DC2423E9-8022 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5E0 907 044 AQ HW: 5E0 907 044 AQ Component: Climatronic H04 2001 Revision: 00001K00 Coding: 01110004000110011005004C0010102A Shop #: WSC 73430 031 00063 ASAM Dataset: EV_ACClimaBHBVW37X 006146 ROD: EV_ACClimaBHBVW37X_006_SK37.rod VCID: 74B0273DCE3BA95A1BB-8020 Fresh air blower control module (front): A/C pressure/coolant temperature sensor: Air quality sensor: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG Component: BCM MQBAB H H36 0253 Serial number: 01001725700566 Dataset Number: V03935270GF 0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 094E66C9B9B9C4B258D-805C Wiper motor control module: Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS371 170817 051 0915 Serial number: 887253F0401722900084 Coding: 164DDD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 047 0105 Serial number: S3Y17M09D22H04M56S24 Coding: 00885D Anti-theft alarm system sensor: Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171 Component: Sensor, DWA 005 0316 Serial number: 000000000ZY1716502QX Alarm horn: Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605 Component: Sirene, DWA 005 0314 Serial number: 00002856223971952672 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb Part No SW: 5QA 919 294 B HW: 5QA 919 294 Component: PDC 8 KanalH07 0044 Serial number: 000308418617254 Dataset Number: V03935256AD 0001 Coding: 0471151151 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_EPHVA18AU3700000 009035 ROD: EV_EPHVA18AU3700000_009_VW37.rod VCID: 4BC29CC1F34596A2AA1-801E No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb Part No SW: 5Q0 907 572 J HW: 3QF 907 572 Component: ACC BOSCH MQB H10 0654 Dataset Number: V03935261BL 0001 Coding: 3300408941FFC728949C810520400600000000000000000000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_ACCBOSCHVW416 002006 ROD: EV_ACCBOSCHVW416_002_VW37.rod VCID: 3E24C515B0F7330A3DF-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH Component: Airbag VW21 006 0703 Revision: -------- Serial number: 003W4PJJ7YP$ Dataset Number: V03935266KC 0001 Coding: 98CCC000000000005C5400CC008800000065 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_AirbaVW21TS6VW48X 001014 ROD: EV_AirbaVW21TS6VW48X_VW37.rod VCID: 05566AF995A1A0D23C5-8050 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 454 000 709 17 Component: SideSensor_Df 008 0887 Serial number: 35700000000F74CCB820 Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 454 000 709 17 Component: SideSensor_Pf 008 0887 Serial number: 35800000000474CCB82X Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 454 800 709 17 Component: SideSensor_Dr 301 0148 Serial number: 35100014F0112000000X Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 454 800 609 17 Component: SideSensor_Pr 301 0148 Serial number: 35200DDEE1312000000S Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 454 803 008 17 Component: FrontSensor_D 304 0149 Serial number: 35500C75ACA10000000R Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 521 KQ HW: 5Q0 953 569 B Component: Lenks.Modul 100 0245 Revision: FF035035 Serial number: 20170919500631 Dataset Number: V03935261HE 0001 Coding: 6414 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_SMLSVALEOMQBLRH 001007 ROD: EV_SMLSVALEOMQBLRH.rod VCID: 0B425CC1B3C5D6A26A1-805E 1 Fault Found: 291104 - Temperature Sensor for Heated Steering Wheel B1455 01 [008] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 254 Reset counter: 226 Mileage: 12981 km Date: 2018.11.21 Time: 14:44:16 Ubat 30 Voltage: 12.20 V Internal error state: 0 LIN_Temp: 254 Isense: 0 Max.Leistung: 110 PWM: 0 Offset: 251 Slope: 133 kp: 18 OUT: 50 Temperatur Statisch: 30 p_t_soll_0: 34.00 °C p_t_soll_1: 39.00 °C p_t_soll_2: 44.00 °C ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5E0 920 950 F HW: 5E0 920 950 F Component: KOMBI 303 0310 Coding: 27A502082D80860001886B011001000000000000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_DashBoardVDDMQBAB 009060 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 290E06495979A4B278D-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C Component: GW MQB High 436 4304 Revision: -------- Serial number: 0006846032 Dataset Number: V03935258RY 0001 Coding: 030100347F085700EB00025A1C0F00010001070000000000000000000000 Shop #: WSC 73430 790 00000 GVL: 01563C0000000100C00C80000002C80000000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013023 ROD: EV_GatewNF_VW37.rod VCID: 3332E4218BB5EE62C21-8066 Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 C HW: 3V0 919 719 C Component: E221__MFL-PR6 H02 0160 Serial number: 000000000C0171020917 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1050 Serial number: 75886000001709200BEB No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb Part No SW: 3G0 857 511 G HW: 3G0 857 511 G Component: FLA H10 0003 Revision: AA001001 Coding: 0404010700000100000000 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_HighBeamAssisAU33X 001017 ROD: EV_HighBeamAssisAU33X_VW37.rod VCID: 2C00FF5D568BB19A83B-8078 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B Component: TSG FS 011 0032 Serial number: 0000279287507 Dataset Number: V03935252QV 0001 Coding: 001D0020D001040000001100 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 47CAA0F1EF2D72C28E9-8012 Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Component: FOND_FHSG_DRV 006 0007 Serial number: 00000000000016355255 Coding: 1D0200 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R Component: EPS_MQB_ZFLS 129 1072 Dataset Number: V03935242GR 0001 Coding: 8107 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_SteerAssisMQB 013144 ROD: EV_SteerAssisMQB_013.rod VCID: 45D6AAF9D52160D27C5-8010 No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb Part No SW: 3Q0 907 338 HW: 3Q0 907 338 Component: FCM MQB Low 002 0286 Serial number: 19091710524414 Dataset Number: V03935265KN 0001 Coding: 000000070100046600003D01010000000000000000000000000000000000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_MultiModulContiVW48X 001010 ROD: EV_MultiModulContiVW48X_001.rod VCID: 72BC2125B42FA76A097-8026 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B Component: TSG BFS 011 0032 Serial number: 0000279685442 Dataset Number: V03935252QY 0001 Coding: 001D0020D001040000001100 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 46D4ADF5E8276BCA75F-8012 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Component: FOND_FHSG_PSG 006 0007 Serial number: 00000000000016394633 Coding: 050200 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb Part No SW: 565 035 020 A HW: 565 035 020 Component: MU-H-ND-EU H54 1163 Serial number: A855I0HB026411 Dataset Number: V03935270ZF 0001 Coding: 03730101FF00000051111201008802002F0100C601200500FF Shop #: WSC 73430 790 00063 ASAM Dataset: EV_MUHig4CGen2HBAS 001001 ROD: EV_MUHig4CGen2HBAS_AU37.rod VCID: 0B425CC1B3C5D6A26A1-805E Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5E0 919 606 D HW: 5E0 919 606 D Component: ABT_High-2 H50 9130 Serial number: SKZ6ZHT2660045 Data carrier: Subsystem 2 - Part No SW: V03 959 820 BL HW: ----------- Component: ECE 2023 --- 0310 Serial number: -------------------- Compact disc data bank: Subsystem 3 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1016 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L Component: Anhaenger H27 0260 Revision: 8C001004 Serial number: 0455628288 Dataset Number: 5E0124t____ 0005 Coding: 0100000202000000 Shop #: WSC 73430 790 00000 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 40D8BBEDCA0345FA4F3-8014 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B Component: RVC Compact H12 0231 Dataset Number: V03935257YE 0001 Coding: 0473010123002017000040 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod VCID: 392ED609A9D9143208D-806C No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1L H06 0005 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 7EA40515F077F30A7DF-802A 2 Faults Found: 0789 - Light Bulb for Low Beam C1198 01 [040] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 0 Mileage: 21329 km Date: 2019.08.18 Time: 12:02:32 0821 - static cornering lamp C119A 01 [040] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 0 Mileage: 21329 km Date: 2019.08.18 Time: 12:02:32 ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1R H06 0005 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 7EA40515F077F30A7DF-802A 1 Fault Found: 1129 - Bulb for DRL and Parking Light C123A F7 [040] - Overtemp Protection Active Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 0 Mileage: 39362 km Date: 2022.07.11 Time: 13:38:58 End----------(Elapsed Time: 01:45, VBatt start/end: 11.7V/14.8V)----------- Copy faults 1.txt
Skoda configurator.
What ever mk they are is a reversing camera an option or standard as the brochure makes no mention of it for an Octavia?
EPC Warning light
I do intend to do this but haven't used my cable for about 4 years so 1 - I can't find it and 2 - when I do find it it will probably need updating so I haven't got round to it yet which is why I posted. Is a weak battery a likely cause do you think?
EPC Warning light
Thanks @Breezy_Pete Typical me - ask the questions before knowing if I can do it myself - anyway it's the EPC warning light I am talking about.
EPC Warning light
I realise I have entitled the thread EPG light. I meant to say EPC light. Mods, can this be corrected?
EPC Warning light
Tow bar ordered as a factory fitted option when car was ordered, by me, in 2017. The figures I quoted were for the cam belt replacement. Spark plugs replaced as per Skoda servicing schedule.
Skoda configurator.
Building my next Octavia on the Skode configurator I can't find any reference to a reversing camera as a standard fitting, optional fitting or as an option in the current brochures. Do 2023 Octavias have the option or is it standard? I see front and rear parking assists and manœuvre assists is this the reversing camera?
EPC Warning light
Quoted close on a grand by local dealer, pleaded loyalty for long standing customer and got it done for just under £800.
EPC Warning light
So there I was 10 minutes/5 miles into a 50 mile journey towing my caravan with my Octavia 1.5TSi ACT DSG when up pops the EPG warning light and "Engine Limited to 4000 revs. The caravan had to get to where I was going and the car was still moving so I carried on at a fairly sedate 40mph or 50ish if I pushed it in Sports mode only S4 though wouldn't change up unless going down hill. Everything very sluggish, acceleration, gear changes, start stop error, unable to achieve ACC speed settings. Got to my destination to drop off my caravan for warranty work and, about an hour later, fired up the car. No sign of EPG light, car behaving normally and home, minus caravan, with no problems. Is it likely a failing battery could have caused this as, since the pandemic, the car has had a lot less use and I have been charging the battery fortnightly with an eTec charger? I hadn't charged the battery for about 6 weeks recently though as inclement weather stopped me when I should have been doing it, but have made several short journeys. I am thinking that if the battery is quite discharged but managed to start the car OK perhaps the additional load of the caravan electrics was just to much for it. The battery was new, with the car, in November 2017 Any thoughts anyone.
Detachable tow bar. November 2017 Octavia 1.5 TSi ACT DG
Thanks everybody for the information. I think the best part of 50 quid is ever so slightly more than I am prepared to pay for a couple of small pieces of plastic. The button is still pushable without its red top and duck tape can keep the lock clean.
This is very useful thanks. It looks like I need 33 as I assume 34 is the lock. Unless the cover comes with 34 and the push button comes with 33 of course. May I ask where this diagram comes from and/or can you post a link or PM me a link to it?
Hi folks. Upon removing the hook from the tow bar today I find that the top of the push button and consequently the lock cover have fallen off during the journey. Can anyone shed any light on where replacements can be found. I think the tow bar is a Westfalia but am not sure and there is nothing like it on their website.
Nearside front parking sensor sounding randomly on movement of steering wheel.
As the title says. Nearside front parking sensor sounding randomly on movement of steering wheel. Any ideas why? My 2017 1.5TSi ACT DSG hatchback. Happened when outside temp was -4.5 C if that has any relevance. Possible ice in on or around the sensor. Nothing visible outside.
