EPC Warning light
So there I was 10 minutes/5 miles into a 50 mile journey towing my caravan with my Octavia 1.5TSi ACT DSG when up pops the EPG warning light and "Engine Limited to 4000 revs. The caravan had to get to where I was going and the car was still moving so I carried on at a fairly sedate 40mph or 50ish if I pushed it in Sports mode only S4 though wouldn't change up unless going down hill. Everything very sluggish, acceleration, gear changes, start stop error, unable to achieve ACC speed settings.
Got to my destination to drop off my caravan for warranty work and, about an hour later, fired up the car. No sign of EPG light, car behaving normally and home, minus caravan, with no problems.
Is it likely a failing battery could have caused this as, since the pandemic, the car has had a lot less use and I have been charging the battery fortnightly with an eTec charger? I hadn't charged the battery for about 6 weeks recently though as inclement weather stopped me when I should have been doing it, but have made several short journeys. I am thinking that if the battery is quite discharged but managed to start the car OK perhaps the additional load of the caravan electrics was just to much for it. The battery was new, with the car, in November 2017
Any thoughts anyone.
Edited by YMe
Spelling.
@YMe Is it the EPC light on?
Was your car ordered from the factory with Towing Preparation and has a factory fit towbar, or one fitted later?
EDIT.
I see factory fit.
http://briskoda.net/forums/topic/509842-detachable-tow-bar-november-2017-octavia-15-tsi-act-dg
PS.
Out of interest / nosy.
Did you get the cam belt replaced and how much did it cost.
http://briskoda.net/forums/topic/505746-67-plate-cambelt-change
Edited by toot
Quoted close on a grand by local dealer, pleaded loyalty for long standing customer and got it done for just under £800.
@YMeI take it that was the fitting of the tow bar.
 Did the car have Tow Bar preparation from the factory, as in the extra cooling?  Not that i expect that is the issue.
Has your car had the spark plugs replaced?   You will need to have it read for any fault codes, like misfires.
http://briskoda.net/forums/topic/389338-tow-bar-prep-already-fitted
http://briskoda.net/forums/topic/458487-towbar-prep-what-is-done-wgen-built
Tow bar ordered as a factory fitted option when car was ordered, by me, in 2017.
The figures I quoted were for the cam belt replacement.
Spark plugs replaced as per Skoda servicing schedule.
I realise I have entitled the thread EPG light. I meant to say EPC light.
Mods, can this be corrected?
Edited by YMe
  • YMe changed the title to EPC Warning light
  • Sponsor
Reported for mod attention.
As a note to any reader, you can do this to your own posts to request attention. Pick 'report' from the dropdowns when you click the three dots on right of post.
Much more effective as mods simply can't read every post.
Actually being a Freedom member you could edit it yourself @YMe.
Go into the edit function of the first post and you get to edit the title or any other part of it. 🙂
Edited by Breezy_Pete
Thanks @Breezy_Pete
Typical me - ask the questions before knowing if I can do it myself - anyway it's the EPC warning light I am talking about.
Edited by YMe
  • Sponsor
You can also edit the title yourself, I spotted when I noticed you have Freedom membership, see later edit to my previous.
  • Sponsor
Your signature suggests that you have, or have access to VCDS, so a full autoscan seems like the natural course of action to discover what the engine ECU thinks the trouble is.
sp
I do intend to do this but haven't used my cable for about 4 years so 1 - I can't find it and 2 - when I do find it it will probably need updating so I haven't got round to it yet which is why I posted. Is a weak battery a likely cause do you think?
  • Sponsor
Sounds unlikely to me, do you have a meter with which to measure its voltage some hours after last use?
Carried out a full Auto Scan and I have come up with this:-
Saturday,08,April,2023,18:23:42:02159
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0  HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: XXXXXXXXXXXXXXXX  License Plate:XXXXXXX
Mileage: 43704km-27156mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 4B 52 5F 69 6C D6
          D7
VIN: XXXXXXXXXXXXXXXXX   Mileage: 43704km-27156miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 A    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 4937
   Revision: 81H22000    CVN: F7D9BFAF
   Coding: 012500322474050800000000000000000000000000000000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM15TFS01105E906018A 003006
   ROD: EV_ECM15TFS01105E906018A_003_AU37.rod
   VCID: 231214613B557EE2321-8076
   VINID: 91D4928877951DA0011C608200072709FF
4 Faults Found:
17159 - Databus
          U1123 00 [032] - Received Error Message
          Intermittent - Not Confirmed - Tested Since Memory Clear
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
37663 - Turbocharger/Supercharger Wastegate 1
          P25B4 00 [032] - Stuck Closed
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 43503 km
                    Date: 2023.04.06
                    Time: 11:06:57
                    Engine RPM: 1091.50 /min
                    Normed load value: 2.7 %
                    Vehicle speed: 19 km/h
                    Coolant temperature: 105 °C
                    Intake air temperature: 23 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 14.740 V
                    Unlearning counter according OBD: 37
                    Charge pressure actuator: specified position: 29.50 %
                    Bypass valve f high press turboch turbine inlet: actual value: 49.98 %
                    Charge pressure actuator: adaptation for lower stop: 2884.4 mV
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 51
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 7
                    Bypass valve for high press turboch turbine inlet: uncond volt: 1335.6 mV
37664 - Turbocharger/Supercharger Wastegate 1
          P25B3 00 [032] - Stuck Open
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 43502 km
                    Date: 2023.04.06
                    Time: 11:04:41
                    Engine RPM: 1735.50 /min
                    Normed load value: 1.6 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.720 V
                    Bypass valve f high press turboch turbine inlet: actual value: 49.96 %
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 80
                    Bypass valve for high press turboch turbine inlet: uncond volt: 1335.2 mV
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 049 G    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1005
   Revision: 00005026    Serial number: CU501709166728 CVN: 6F1C2C4E
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 41DEBEE9C1094CF240D-8014
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CF    HW: 5Q0 614 517 AD
   Component: ESC           H25 0513
   Revision: 00000000    Serial number: 62617000000039
   Coding: 24078A91242721724079060240C3242451248402600224723621F070C002430000000012121212B8586C384E4484EE
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
   VCID: 77AA1031DF4DC2423E9-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 01110004000110011005004C0010102A
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 74B0273DCE3BA95A1BB-8020
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001725700566 Dataset Number: V03935270GF 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094E66C9B9B9C4B258D-805C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170817  051 0915
   Serial number: 887253F0401722900084
   Coding: 164DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  047 0105
   Serial number: S3Y17M09D22H04M56S24
   Coding: 00885D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1716502QX
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0314
   Serial number: 00002856223971952672
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0044
   Serial number: 000308418617254 Dataset Number: V03935256AD 0001
   Coding: 0471151151
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA18AU3700000 009035
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4BC29CC1F34596A2AA1-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935261BL 0001
   Coding: 3300408941FFC728949C810520400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 3E24C515B0F7330A3DF-806A
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PJJ7YP$ Dataset Number: V03935266KC 0001
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 05566AF995A1A0D23C5-8050
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 000 709 17
   Component: SideSensor_Df  008 0887
   Serial number: 35700000000F74CCB820
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 454 000 709 17
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000474CCB82X
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 454 800 709 17
   Component: SideSensor_Dr  301 0148
   Serial number: 35100014F0112000000X
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 609 17
   Component: SideSensor_Pr  301 0148
   Serial number: 35200DDEE1312000000S
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 803 008 17
   Component: FrontSensor_D  304 0149
   Serial number: 35500C75ACA10000000R
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 KQ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF035035    Serial number: 20170919500631 Dataset Number: V03935261HE 0001
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 0B425CC1B3C5D6A26A1-805E
1 Fault Found:
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 226
                    Mileage: 12981 km
                    Date: 2018.11.21
                    Time: 14:44:16
                    Ubat 30 Voltage: 12.20 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 251
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 950 F    HW: 5E0 920 950 F
   Component: KOMBI         303 0310
   Coding: 27A502082D80860001886B011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 290E06495979A4B278D-807C
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   436 4304
   Revision: --------    Serial number: 0006846032 Dataset Number: V03935258RY 0001
   Coding: 030100347F085700EB00025A1C0F00010001070000000000000000000000
   GVL: 01563C0000000100C00C80000002C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3332E4218BB5EE62C21-8066
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000C0171020917
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1050
   Serial number: 75886000001709200BEB
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 G    HW: 3G0 857 511 G
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404010700000100000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 2C00FF5D568BB19A83B-8078
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        011 0032
   Serial number: 0000279287507  Dataset Number: V03935252QV 0001
   Coding: 001D0020D001040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 47CAA0F1EF2D72C28E9-8012
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000016355255
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935242GR 0001
   Coding: 8107
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D6AAF9D52160D27C5-8010
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 19091710524414 Dataset Number: V03935265KN 0001
   Coding: 000000070100046600003D01010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BC2125B42FA76A097-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       011 0032
   Serial number: 0000279685442  Dataset Number: V03935252QY 0001
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 46D4ADF5E8276BCA75F-8012
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000016394633
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 020 A    HW: 565 035 020
   Component: MU-H-ND-EU    H54 1163
   Serial number: A855I0HB026411 Dataset Number: V03935270ZF 0001
   Coding: 03730101FF00000051111201008802002F0100C601200500FF
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHT2660045
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 820 BL    HW: -----------
   Component: ECE 2023  --- 0310
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0455628288 Dataset Number: 5E0124t____ 0005
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 40D8BBEDCA0345FA4F3-8014
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Dataset Number: V03935257YE 0001
   Coding: 0473010123002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 392ED609A9D9143208D-806C
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA40515F077F30A7DF-802A
2 Faults Found:
0789 - Light Bulb for Low Beam
          C1198 01 [040] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 21329 km
                    Date: 2019.08.18
                    Time: 12:02:32
0821 - static cornering lamp
          C119A 01 [040] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 21329 km
                    Date: 2019.08.18
                    Time: 12:02:32
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
1 Fault Found:
1129 - Bulb for DRL and Parking Light
          C123A F7 [040] - Overtemp Protection Active
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 39362 km
                    Date: 2022.07.11
                    Time: 13:38:58
End----------(Elapsed Time: 01:45, VBatt start/end: 11.7V/14.8V)-----------
Copy faults 1.txt
Edited by YMe
I have cleared all the faults and been for a short test drive. Another auto scan showed all controllers "no faults found."
I'm not unduly bothered about the heated steering wheel fault as it is an old one and the heated steering wheel gets warm when I want it to and, to me. that is all I am looking for. Don't pretend to understand the mis-fire and Westgate stuck open stuck closed though.
This is the first time I have done an auto scan since I did the tweaks in my signature and it is the first time I have seen my auto scan with no faults showing.
The lighting fault codes I ignore as there is nowt wrong with the lights and never has been. Funny that it has disappeared now though.
  • Sponsor
See what faults return by scanning semi-regularly until one does, or the EPC light reappears. The first engine fault to reappear is likelier to be the true cause, subsequent ones may be 'collateral issues'.
Battery fully charged Saturday 8th May. Didn't check the voltage after charging. Ctec charger until green light lit up.
After a 20 mile run in two stages of 10 miles out, 2 hours off, and 10 miles back, on Sunday, tested battery today and it reads 12.4 volts. Battery is over 5 years old is it failing?
Edited by YMe
  • Sponsor
Might be getting past its best, but I'd be rather surprised if it has anything to do with those faults.
I wondering if the extra load of the caravan electrics on top of a failing battery may have something to do with this as driving 100 or so miles, without the caravan, since clearing the faults, nothing has re-occurred.
Edited by YMe
I have replaced the battery as the resting voltage was hovering just under 12.5 and it is 5½ years old so not at its best. Travelled several hundreds of miles towing since and problem <so far> has not reappeared.
Edited by YMe
