Everything posted by vvojta
- Mib 1 - Mib 2 retrofit Help
@pab567 Would you please be able to help ? I've found out that you need ODIS coding to remove the CP, is it a necessity or Would I be able to do it through SD card (green menu) or OBD11 ? In the future, I'm planning to compile every bit of information to sum it up and make a more straight forward guide, because when I did it, there were a lot of different guides and none of them were full. Each time I had to take some information from different sources, a bit of my knowledge and compile everything to make it to this point, so I would really appreciate the help.
Hi, could anyone please help me with retrofitting, I did every step, from buying the MIB 2 unit and display, to flashing it with "mib-std2-pq-zr-toolbox" but when I turn the ignition on, the display turns on with standby clocks that I can scroll through (different faces ), but none of the buttons do anything (parking sensors normally show up),(by the blue dev screen on the photo below I know that they work even on this screen, they just don't do anything). But when I connect diagnostics, the screen flashes with standard interface for a moment and the turning back to clocks, then after choosing module 5F Multimedia, the screen comes alive, everything works, buttons, touch, with that I was able to change language from Russian, update the software and everything, but when I disconnect the diagnostics, it goes back to clocks. The software is updated to version 480 (photo is before the update) but even then it is the same. After disabling component protection from the toolbox, it still shows up as a fault in diagnostics Would appreciate any help.
Rear Seat Release Mechanism Issue
I've also had this issue, the frame was a bit lifted and couldn't be placed back, after an agonizing hour of trying to lift it, I gave up..... Took a rubber mallet, gave it a whack..... Now it works like a charm.... 😅
