CrazySkoda
Everything posted by CrazySkoda
  1. https://mib-helper.com/index.php?train=men3_eu_sk370_p0314l#details
  2. No coding needed, camera did automatically
  3. Yes, its best to not mess if there is limit. Youre welcome. In my case i had this path: But thats different story
  4. Picked this up from russian forums, they seems to know alot better about this stuff: – MEN3_EU_SK370_P0113P_0469; – MEN3_EU_SK370_P2131P_0741; – MEN3_EU_SK370_P2135P_0742; – MEN3_EU_SK370_P0314L_1233; – MEN3_EU_SK370_P0393L_1310; – MEN3_EU_SK370_P1185L_1760; – MEN3_EU_SK370_P2345L_1790; – MEN3_EU_SK370_P3225L_1798; — MEN3_U_SK370_P3355L_1800. Based on the metadata of firmware, the following transitions are permissible: 0464 => 0469 => 0741/0742 => 1233/1310/1760/1790/1798/1800
  5. Go with P2345L and then to P3355L P3355L is the latest v (1800) maybe there is newer. But on mibsolution that is latest one. And there is no newer one available on the internet afaik. You can put both unzipped folder inside the root of the usb drive. And then follow the instructions: https://youtu.be/o0RIdpKQ2b8?is=Yn6CeyB0U3i_uPQ1
  6. Version should match if its same SK370 Try different usb drive or buy cheap usb c to usb a otg adapter. Thats how i did mine.
  7. P3355L is 1800v and its latest on mibsolution You can go middle one, and then download the 1800 if you want, or stick to 3225l which is 1798v
  8. I dont think so, havent run my engine when updating. But i know that i needed to buy USB OTG, normal usb a to usb c didnt work. Is there difference or it was just bad cable. I dont know. Try other cables or usb drives if you have?
  9. Check this out if you havent already. Thats the correct steps to update: https://youtu.be/o0RIdpKQ2b8?is=Yn6CeyB0U3i_uPQ1
  10. Please try to unzip the content from the folder to the root of usb instead?
  11. Hi, i think that you need to use USB C OTG adapter instead,
  12. How did you connect it to the car?
  13. I have contacted the seller, and let him know about everything. Camera, compatibility with scala and mib unit. Seller was really helpfull with solving the case and fast at the conversation (you know that sometimes it takes days for response) so i will just let it rest. To conclude, i have just installed camera. Handle (boot opener) fits ok. Image is ok for the price. Now i know why they charge so much to fit oem one in the shops 🤣
  14. Update on the topic! Seller sent me a new camera, i had to pay for a cheapest item in the seller's shop.(8€ for some cable) And guess what? Camera works. That answers the questions why there was no trajectory and black and white image only. Thanks everyone who helped in my case!
  15. That means that there is no newer version of that part in firmware. Had the same thing when i was updating fw. You can update without problems!
  16. Hi, to help others, tutorial how i activated Hill Hold on Scala my2020. Hw number: 2Q0614517N Sw number: 2Q0614517AP Based on info from obdeleven, coding is: Hill hold assist Module 03 Brakes Long coding Activate byte 47 - Bit 6 (was 0B, now 4B) Activate byte 51 - Bit 1 (was D0, now D2) But i couldnt get it enabled (function not available) Instead, i changed the 0B to 4B and D0 to D2 in the long code. After that i got Hill assist options inside adaptations, and got the HA running!
  17. You can go with P2345L version in between, then to the latest: P3355L (1800)
  18. Before skoda scala 1.0 tsi, had the ciroen c3 1.4 hdi , and i can tell you for the city, the c3 was winner. It used fuel like a lighter. Yes its smaller. But skoda scala consumes 9.4l gasoline city drive. And i do like to push the pedal xD
  19. Hi, download the one matching your SKGPx https://mibsolution.one/#/1/9/MEN2%20-%20LG
  20. Yes when i started to update, it supposed to reset screen and start the update, but screen was black for 10 minutes. I forced to reboot by holding the power. (On off button)
  21. Hi everyone, im Scala owner from Croatia. Got in the world of customisation of the vehicle with obd11, soon after, got the Vas 6154a, and started to learn new things. Happy to share knowledge i got about things i done to the vehicle. (successfully, because there is alot of copy paste codes claiming that it works for Scala eg, but it doesnt.
  22. No worries, at first update, display stuck black. But after reset it booted and started to do the update. Let us know how it goes
  23. I went from the bottom one to second and top one is latest(1800) dont know exact version number. (Check image that i posted above) You can download only two versions SK370:
  24. I had both versions in their folders on the usb, i had to buy usb c to usb a otg adapter to attach my usb stick. And after flashing 1st version. I checked that everything is ok. Than proceeded to second, latest version.
  25. Hi all, can someone tell me what is difference between this 2 versions? I have upper version radio, and the camera doesnt work (black white image, and no trajectory(retrofit from aliexpress - sinosmart) but the bottom one works. ( from the post from Scala retrofit reverse camera) If anyone knows, thanks!
