Updates in blue
1. 034 motorsport free flowing exhaust manifold
2. 034motorsport Vortex breather kit
3. 034motorpsort fuel pressure gauge
4. 42DraftDesign 3 inch racing decat modular 3 pieces ceramic coated pipe
5. Miltek cat back resonated 2.5 inch system
6. 034motorsport phenolic intake manifold spacer-transiton one from large to small port
7. Denso Iridium IK 24 pregapped to 0,024"
8. Hyperboost adj. DV
9. Ecotek Emissions Control Valve CB26-P Blue
10. Piperross Chrome Valve for CB26-P
11. ECS Tuning Adjustable Fuel Pressure Regulator
12. ECS Race N75 Frequency Valve 1.8T
13. ECS Silver Lightweight/Under Drive Pulley Set For 1.8T/2.0
14. Air intake VDT www.modshack.com
15. MAF Audi TT 225HP
16. Air diffusor and 90mm air duct to air box
17. HKS turbo timer
18. www.rsrmotorsport.com custom remap (with flow bench adaptng of new MAF housing to the 225 ones map spec)
19. K04-001 turbo,
20. Siemens Deka 440cc injectors
21. Forge FMIC- FMSKOFMIC
22. Forge TIP FMGOLFIND
23. Forge Silicon Turbo Hose Kit 1.8T 180 FMKT005
24. Forge DV relocation kit 150/180hp 1.8T
25. Forge Quickshifter 5spd FMVAG5QS
26. Verdict Motorsport Shift Bracket Bushings
27. 42DraftDesign Mk4 & Mk5 Shifter Cable Bushings Fitment
28. SFS performance custom TIP
29. LCR (or Lamborghini Galardo) 4bar fuel pump sender unit 8L0919051H (thanks to your site I found perfect match without starvation prblems with 044 I had),
30. Neuspeed 1.8T 180 Degree Thermostat
31. Neuspeed 180 Degree 3 Pole Fan Switch
32. Neuspeed Connector Conversion Kit for 3 pole fan switch
33. Neuspeed Front Anti-Roll Bar 25mm
34. Neuspeed Rear Anti-Roll Bar 28mm
35. Neuspeed Lower Strut Brace Billet
36. APR carbon strut bar
37. SPEC SV363F Skoda Octavia 1U 97-05 1.8T STAGE 3+ clutch
38. SPEC SV21S Skoda Octavia 1U 97-05 1.8T STEEL FLYWHEEL
39. D2racing Track racing coilovers
40. Ground Control camber caster kit
41. H2Sport - Sport Spindle H2S1J0407001K
42. LSD QUAIFE QDF10R
43. Audi TT bigger tier rods and tie rod ends (16mm thread)
44. Powerflex bushing all around
45. Zimmermann Formula 312mm drilled front discs,
46. Zimmermann Formula 256mm drilled rear discs
47. EBC yellow stuf front and rear pads-track tested by myself-great ones
48. Custom front braided ss brake lines
49. Mintex racing brake fluid,
50. Castrol EDGE Sport 10W60 engie oil,
51. Castrol TAF-X transmission oil,
52. TWS 8x19 ET35
53. Falken 215/35/19 F452 outer diameter 24.9" instead of 25.1" for 225/40/18
54. Bixenon kit 6000K
55. Painted in red and covered with clear lack rear lights,
56. dark grey perforated leather seats and door panel inserts,
57. SPC Performance Camber and Toe Shims 71520 and 71530.
58. TyrolSport Brake Caliper stiffenings kit with SS rings snap upgrade
59. Qstarz BT818X 5Hz GPS reciever
60. dark grey perforated leather seat insert and door pannels
61. Cast LCA Audi TT
62. Golf R32 steering rack
63. new custom braided front and rear brake hoses
64. Large port intake manifold
Davor
