Everything posted by scubasad
What next? Had enough now.....
Dropping the wife off at A&E a short while ago and when I pulled up outside, the stop /Start decided to work and cut the engine ( this has been sporadic to say the least and i fully expect to have to change the battery at some stage) however, when I took my foot off the brake I had message come up to "Start car with key" which I duly did, but then I get the engine management light and glo plug light come on. Management light is solid, glo plug light is flashing. Drove home (only a short journey) and switched off the car and grabbed the trusty owners manual but nothing really mentioned except what the lights are if they come on? Started the engine again and just the management light came on.My question is, could it be an issue with bad or poor glo plugs which is actually the issue with the stop/start function or is it something else? Will pop it into my mate tomorrow to put his code reader on, but wondered if anyone may have had similar issues?
water ingress drivers footwell?
sadly, it would appear the issue is not sorted after all the rain we have had. Opened car door Monday morning and found another pool of water on the rubber mat. I`ve been back to the garage and they are going to have another look on 18th feb (earliest they can fit me in). This now has me wondering if there is anywhere else this could be blocked apart from the front drains which have been dealt with, or if it is actually coming in from the windscreen? Extremely frustrating as I just want to enjoy the car, but all this is putting me off somewhat...
colombus sat nav upgrade
Can anyone tell me how to check the current version of this as far as satnav. I don`t want to purchase the satnav upgrade if it already has the latest/last one done...
Heated seat replacement / retrofit with universal part?
Had you considered taking the seat out and removing the covers to find the break and repairing? I did this when I had my range rover p38. The breaks are usually easy to find due to scorch marks.. I just soldered in fresh bits of wire and it worked a treat...
I went to my local independant Skoda authorised garage in the finish. for the sake of an hours labour it was worth it.. Cleared the blockage in drivers side drain, checked passenger side too. All good and no more water inside.. And given the rain we`ve just had , it has had a bloody good test...
I had wondered about using strimmer line? i have some 6mm line that i use for the heavy duty strimmer but still quite flexible. Am guessing that should go through to at least prove if there`s a blockage?
Yes it does have the sunroof, but am really puzzled by this now. Substantial puddle of water yesterday. dried it all up, has been raining pretty much all night and this morning when I check barely anything at all just a small patch about 3" in diameter. splashes evident under dash near throttle pedal, but cannot feel any wetness under the dash on a cursory feel.. If it is the sunroof, how easy is it to access the drain hoses to check for blockages/or detachment?
was looking to do an upgrade to the sat nav on my colombus unit and reliably informed by satnavishop that there is no upgrade after 2020-2021 for the 2014 model in my vehicle. Anyone shed any light as to why no further upgrades available?
After just spending out on Cambelt/water pump, gearbox oil change, both front wishbones and headlight sensor, I had rather hoped i`d cracked this but it appears i now have water ingress into the drivers footwell? It doesnt appear to be a great amount but it is worrying nonetheless. I have the panoramic roof that is also half a sunroof but there doesn`t appear to be any staining or wet around the headlining so am wondering if this might be a blocked scuttle or something like that? Is this a common issue and whats the best way to rectify please anyone?
left front level control system sensor
I went for middle ground in the finish and got an oem version from Skodaparts.com in Czech republic. Very reasonably priced and being fitted tomorrow along with two new wishbones..
2014 skoda superb estate rear left boot lid cable grommet replacement..
It would appear that there are indeed plugs on the loom in the rear quarter, but sadly they are too large to fit through the new cable grommet so I`ve had to cut all 15 (3 groups of 5) and splice after threading though the new grommet. Not sure how many have heard of the wago electrical connectors, but I have used these rather than have to solder and heatshrink 15 lots of wire. All good, new grommet in and no further water ingress.
6 speed DSG auto box oil change
oddly enough the initial quote wasn`t from a main dealer, but the second quote of £300 inc vat was from a Skoda authorised dealer who I have used a lot in the past, so once the wishbones are done at my local garage, I will be getting it done at the Skoda authorised dealer.
yes it`s the 2.0 l tdi estate. Lauren & Klement version
ve had another quote which is much more reasonable and also closer to home. Once Ive had the two front wishbones and the light snsor done in a couple of weeks, ll look to get the dsg oil changed. I have as previously mentioned little to nothing as far as previous history so Im starting from scratch, hence the cambelt change..
Apologies for all the questions, but been a while since I owned a Skoda... Seems to be two trains of thought on the DSG auto gearbox oil change.. Change regularly or leave it be? Having just bought the Superb and never had an auto in my life, and given its done 138k, I thought as i have little to nothing as far as service history that I would get the oil/filter changed in the gearbox.. Initial quote is £413 +VAT for oil, filter and health check (whatever that may be) which seems steep imho but if thats about average how often would you look to change the oil etc?
Superb just had cambelt and water pump done today. My mechanic also put his diagnostic tester on it to locate the fault on the AFS headlight issue and it`s come back with left front level control system sensor open cct/short cct. Genuine part is around £250 from Skoda. Are the aftermarket parts any good as I can get a supposedly OEM part from Amazon for example for under 40 quid? Or do people suggest using genuine parts?
I seem to have finally rectified all issues with the rear wiper not working/squirting, but in doing so the wiring grommet needs replacing.. Is there a plug near the boot lid somewhere that can be unplugged by means of a bit of trim removal to replace this or would it be cut into the loom, fit new grommet then resplice loom? I`ve replaced a section of washer hose which has a joint under the rear quarter white trim and can access the loom there too but didnt really want to have to cut and splice each individual wire if there was a plug somewhere? I need to replace the grommet as I`m getting water ingress through the hole which is dripping into the roof lining and along that white plastic rear quarter trim when the washer jet is used.
Rear Wiper not working
ok, so I found a break in the loom and now have a working rear wiper, but no squirty.. found a split in the squirty tube in same place as wire and the only thing I could think of to join the two pieces together was a section of a pen refill that was a snug fit. done this and still no squirty so topped up washer bottle in case it was low but still no squirty. tried removing the nozzle jet and still nothing comes out. Would the fact that i used a pen refill (smaller diameter) be affecting the ability to push the flow through or am I likely to have another split somewhere? No idea wher the pipe runs after coming down the left rear quarter..
bought a replacement wiper motor unit and after a bit of faff, got it changed over. However, this has not rectified the problem and the rear wiper still does not work when you push the control stalk forwards. Also, there is only a wee dribble from the water jet which is the same as before. still waiting on the handbooks to arrive but did manage to find an online version so I checked for a blown fuse and this seemed to be ok. Could it be the control stalk faulty or is there something really obvious that I`m missing?
2014 Skoda Superb Lauren & Klement 2.0 tdi estate..
Thanks for that. Cambelt was done at 62k so it`s been another 76k and booked in to be changed again early Jan. The light issue will be checked at same time. Am waiting on delivery of said handbooks as there were none with the vehicle when purchased.
Just noticed the rear wiper is not working on the Superb Estate (2014) Is this likely to be a fuse or is motor knackered? Squirter works but when you push the stalk forwards wiper doesnt move. Also with the auto tailgate how easy are these to fit if it is a motor required? Cheers Andy
Been a while, but I bought a 2.0 tdi Skoda Superb Estate with the Lauren & Klement trim yesterday. It`s done 138K but very clean and tidy , no dings, leather all good etc. Cambelt was done as far as I can tell at around 62K so am thinking it may be wise to get it done again now or soon as now done 138K? Also I notice what I assume are possible error messages on the MFD as follows: No bend lighting function AFS, check handbook and Check safe lock, check handbook are these anything to be concerned about? Cheers Andy
Octavia Vrs Estate
hmm, had hoped the mpg might be a tad better than that. getting more than that out my current CR-V....
Octavia Vrs Estate
thinking of early retirement next year and looking to purchase either of two vehicles. Another Honda CR-V or coming back to Skoda and getting a Vrs estate. I know most of the pitfalls round the Honda, but wanted a bit more info on the Vrs if anyone can assist please? I assume they are still cambelts, rather than chain drive, so do water pumps still need changing at same time, and what sort of intervals between these? Are the DSG as economical as manual as I`d like to give one a go but not if there`s a vast difference in fuel consumption. Also, I believe the 2.0 l were £30 road tax upto 2017, is this correct or did it go on after that? cheers in advance for any help guys.... Andy
