Everything posted by Tech1e
Which Key do I have?
All new cars came with two keys. A Comfort spec car came with one remote key (non flip, two buttons) and one of these.
A second Comfort spec key, looks right to me.
Techie's new runabout
Anyone have a spare radio facia? 6Y0 857 231 B41
There is a chap on the Facebook Fabia VRS group who prints them.
Fabia interior light stays on
It isn’t. No factory speakers, no factory wiring.
warning lights !!
Fault code check, probably a weak ABS signal or a wandering wheel bearing.
1) Yeah, the key in the door... 2) Yes 3) About £90 the last time I ordered one from Skoda. 4) No, it's an assembled unit, just replaced them.
Replacement door lock.
You can fit the blank instead of the door lock, but then you are royally fudged if the remote stops working.
Tech1e’s ‘new’ Fabia - Slayer
it does
3 button key does not open the trunk
What model Fabia is it?
- 256mm to 312mm brake upgrade
Skoda Scala 1.0tsi - Tightening torques - summaries of components
I see, so the issue is not needing the manuals, more alack of understanding on how the manuals work. Then Wino's description above helps with that.
Scala workshop manuals Knock yourself out.
ESP light and now car won't start
Surprising a 1.2 has ESP, guess that might be a Danish thing.
Adjusting Handbrake Tension
If you have rear drum brakes (which I imagine most Fabia MKIII models will) I would always strip, clean, and adjust the rear brakes rather than just wanging the cable up.
Disconnected then reconnected front radar and now I get front assist not available message
Afraid so...
Faulty front wheel alignment
Some brands of tyre are more prone to this than others. But a good idea to get it booked in and have a four wheel alignment check done.
Car insurance in lockdown
I would have thought so if it is a change of contract. And who is to say what is essential travel? You can travel to work, you can travel for food shopping, travel to see a child....
Scout CV joint
I can't see why a Scout would be any different, engine and transmission might make a difference but trim I very much doubt. Worth emailing Briskoda parts with the vehicle reg to make sure you get the correct parts.
Fabia 2010 1.2 petrol. Diff seal.
What gearbox?
Convert manual to automatic gearbox
Not physically impossible, but not financially viable by any means.
