Everything posted by varooom
Amundsen MIB2 Firmware Update
Sure, will send you a link now, that is correct page for update too.
TDi glow plug activation and push button start, how to?
If the existing is say AGM and 68Ah rated, and new is AGM and 70Ah, I wouldn't worry if you cannot perform the adaption process. The car will take it's own measurements and learn within a few journeys.
Hillhold
You need to read your PR Codes to know for sure if you have this (mine is UG1 Hill Hold Control) they can be decoded from your VIN by dealer, web chat to Skoda or paying someone on eBay. This is how it operates on my car, and it does work. Was going to post it only works for 2 seconds, so you do need to be quick. See if you can test this on a hill somewhere, ideally a layby.
Have a read of this for Stop/Start engines, if you need to change battery you need to be aware of this.
recharging the battery?
Would have been best to keep with your existing thread probably, but yes you can charge on the car. Positive to the postive pole on battery, and Negative to chassis, not to the battery negative pole. Ideally, go to the car, and take a picture of existing battery and also of the battery area so that you can see the negative clamp and the area behind if possible (don't zoom in too close, need a general overview)
Make sure to leave the car settled for at least 2 hours, ideally overnight so cold. Then test the voltage at the battery terminals as mentioned by @PetrolDave
I can send you link to 0480
MKIII waterpump issues CJZC - CJZE engines
Sadly Nigel I don't have many water pump TPI's, mostly it's about sun roof drains and seals on windows. @peter51 The only thing you can do is have someone in another Country that is willing to put an hour onto erWin Skoda with your VIN to look up all the details you need. They could get you all of the wiring diagrams/repair diagrams and then scour the TPI section to make PDF's from them.
8755 Software Update - Skoda Fabia 2019 Carplay Issue
Yes, in a few moments
Software Update available for Bolero?
Ok, will PM details
I can send you update to 8755 version
I didn't think it would, but worth a check 🤝
There is update to 0253 version As for unlocking features, you have 2x choices, one you can contact a dealer or independant and get a code to unlock (kerrching) Or you can get the radio modified via a "toolkit" which is best discussed in PM.
I need Bolero Update :-)
Yes is current version.
Octavia radio swing update
I will send you link to 8755 version
I will send you link to download 0480 version. Even if you don't use, you can update maps here... https://www.briskoda.net/forums/topic/512842-amundsen-mib2-map-updates-2024/ That way you have a backup to Google maps/Waze etc
I will send you by private message links to download and apply
Amunsen MIB1 Firmware
I will send you a PM with link/details then.
Deleted
If it was activated by factory or dealer, then no. If you unit was hacked to activate these things, then yes.
Deleted
Private Message, you will have link and instructions
Deleted
0369 is the latest version of that firmware.
MEN2_EU_SKGPx_P0080L MU 8755 Since this is the only release I have, you actually have newer installed.
Update sent via PM
@mauinek Did you still need firmware? Sorry I missed your post. @Hdu I will send you 0490 version by PM.
I already did this, look top right for private message system
