juan27
Everything posted by juan27
  1. So I took the battery out and replaced the relay. It is attached to a plastic rail that slides out, it's a bit tight to pass the battery tray but with jiggling you can do it. You'll need a T20 Torx to unscrew it. We've had a couple of inches of snow today, now melting anyway so difficult to tell if it's done the trick. Ideally I'd like to put the meter across the screen terminals but I haven't worked out how to get to them yet. Terminals on the "old" relay showed some signs of corrosion but probably not significant. I'll connect it up to 12v and see if I can get it to click.
  2. No 8 in the e box?
  3. Ok checked both sides of the fuse....
  4. Ok a fair point and I do have a multimeter.
  5. Screen is literally brand new. Appreciate relays are reliable, but to be honest I can't think what else the problem could be on a 2017 car unless someone has been messing about with it. Ok will do
  6. Looks a bit different.
  7. OK I shall try the battery tomorrow.
  8. So I've got round to having a look, anyone got any advice on how to access and change the heated windscreen relay? Looks as though taking the battery out might help but I don't want to disconnect that unless absolutely necessary. Can't see any obvious way to remove the "e box" for access.
  9. The relay I mentioned is about £27 from Hortons. Quite a price but after a Google of the part number seems can't be had massively cheaper.
  10. Sorry 'e-box'? Is that the fuse box in the engine compartment?
  11. Anyone know where the heated windscreen relay is located on a 2017 Yeti L&K 1.4 TSi 4x4? The heated windscreen was replaced by Autoglass last summer but is now not working. The switch lights up but Autoglass say no power at the screen connections. Fuse looks fine. Skoda want £114 just to look at it, so thought I could at least check the relay... I think the part number is 3B0 951 253 can anyone confirm?
  12. It's an easy get out for Skoda to say a phone isn't on their list. Not sure I believe that's the issue really
  13. With the first 245s coming up to three years old (and the pre FL 230's past that age) have owners been getting their VAQ diffs serviced?
  14. My 2017 VRS 245 has just gone in for its second variable service and I've just had the health check video by email. The only thing mentioned was that the "air con service is due" and Just wondering what an air con service entails? I certainly never had any such notice in seven years of owning my Mk2 VRS. Appreciate air con needs re-gassing and the like - but at just over two years old, really?
