Everything posted by wah007
Fabia VRS hissing and whine noise
Hello guys, I was wondering if anyone could help me with an issue I have with my Fabia MK2 VRS (CTHE) . The car recently started making a rattling noise and it turned out to be a bad water pump, so I got this replaced by someone on a forum who said they've done these before, and they replaced this for me. I also had the thermostat replaced at the same time, as the temp gauge needle was acting strange. Oh the journey home after having the pump replaced the car drove fine but without boost. The supercharger seemed to work fine. The coolant hose had popped off the thermostat as it hadn't been clamped on properly, but it has now been secured. The car has a blow off valve which would normally make a loud hissing sound (normal) after releasing the gas pedal but now it makes a slight hiss when pushing down on the accelerator pedal and makes less of a hiss when releasing the accelerator pedal. Long story short, the car is now making a hissing noise and a whiney noise with vibration through the engine bay when accelerating, and there doesn't seem to be any boost. It also judders slightly when moving off. Any help would be much appreciated. Thanks
Coolant hose worm clamp size
Hello, I was wondering if anyone knows the sizes of the worm clamps that secure the coolant hose pipes to the thermostat please? There are 4 hoses that connect to the thermostat. I believe there are 2 different sizes of hose pipes. Thanks
Fabia 1.4 MK2 VRS engine making strange noise
I'll give that a try in the morning and see if I can narrow down where it's coming from. Hopefully it's not something major. Thanks for the tip.
Thanks for the info, I'll have a look at it. There's no loss of coolant and no lights on the dash, but it's still early yet as the noise just started around a week ago, so a warning light might pop up soon.
Thanks for the advice. I'll look into that, not sure if It has. It only started around a week ago and the noise has gotten slightly louder, but nothing that'd get you worried.
@Erreesse It's done 90k miles. I bought the car over 3 years ago and it didn't have much service history. I'm not sure if the water pump or timing chain has been replaced previously.
Hello guys, I have a strange noise coming from the engine bay that started a few days ago, seems to be coming from the rear left of the engine bay. I was wondering if anyone knows what it could be? Someone said that it's the water pump failing. It's more noticeable when I very slightly rev the engine (see video). It's a CTHE engine and it doesn't have any oil / coolant loss. There are no warning lights on the dash and it drives normally. Thanks
Stereo with built-in wireless Android Auto / carplay
I've had a good look at the Chinese ones on Ebay and I've found a few that have wireless Carplay but none of them have wireless Android Auto. I think I'll just keep my current unit as it has the wired Android Auto function already. You can buy dongle separately to turn it into a wireless Android Auto device but then I'd have to have a big ugly dongle sticking out from the USB port of the stereo. Thanks for your help
First I've heard of them mate, I'll have a look at them. I currently have Android Auto on my stereo unit, but it's a wired one. I wanted a wireless one where you don't have to use a USB dongle to connect it to your phone for the wireless function. I might just keep this, as the ones with the built-in wireless function are hard to find.
@DanielFenech Great, thank you. I will check it out.
Hello guys, Does anyone know of a stereo unit that has a built-in wireless Android Auto / carplay functionality? I don't fancy having to connect a wireless dongle to connect my phone wirelessly. I need something that'll be a straight swap. Fabia MK2 (2014) Thanks
Mechatronic issue - Fabia vrs mk2
Thanks mate, what did they charge you when you had it done?
Mechatronic Unit Failure
Yes, that was the one. I have a lot to learn about mechatronics.
Ah right, there must be different ways of repairing them then. There are some videos on YouTube that show them doing it without removing the unit from the car.
Why are they charging so much. Isn't it like 2-3 hours labour and around £200 for the parts.
Wind Deflectors
I have a front driver's side available, it's a Team Heko one. If it's any good to you.
Hello guys, I have a spanner sign flashing on the MFD where the gear numbers are on my Fabia. I've pulled code P17BF00 after scanning with a diagnostic tool, which says is a failing mechatronics unit. Can anyone recommend someone that can repair this in the Manchester area? Someone has quoted me £650 but I have to drive a couple hundred miles to them . Fabia VRS 1.4 DSG Petrol (2014) Thanks
Bulb out warning light - Fabia VRS MK2
@UrbanPanzer Thanks all. I connected the car to VCDS today and the cornering lights option was enabled, I disabled it and no more bulb out warning light.
@UrbanPanzer Thanks, I'm going to get the VCDS plugged in and hopefully that's what it is.
@sepulchrave Thanks, hopefully it's just an easy fix via VCDS, if I can get a hold of one.
@toot Thanks, I'll check the connections for the DRLs. It could also be that the previous owner activated a function that the car doesn't have, as it's been like this since I've had the car.
Someone mentioned that it could be because of the cornering lights function being activated in VCDS. Could this cause the warning to pop up when turning the wheel?
Hello Forum, I was wondering if anyone knows what the issue could be here? When I turn my headlights on and turn the steering wheel left or right (half a turn) the orange bulb out warning error pops up on the dash. Turning the ignition on and off again resets the light.. If I'm driving in a straight line with the headlights switched on then the warning doesn't pop up. With the headlights switched off I don't get any bulb out warning light, even when turning the steering wheel. It only happens when the headlights are on. Fabia VRS MK2 DSG 2014.
List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
I understand what you mean, I'll make a separate thread on it. 👍
Thanks. Not everyone knows how to do it, so I thought that I'd ask on here, and if anyone knows how to do it then they could reply to me. I've asked a few people and they're not too sure.
