Everything posted by mdfabia1969
Brake caliper help
Can someone tell me if these are standard front calipers on my mk1 fabia vrs as when I go to car shop for brake pads get offered ones that don't fit
Fan relay under car
How on earth do you get to the top 2 bracket small nuts?to remove it?what tools do you need .any help appreciated
Breaking Skoda Fabia Vrs mk1
Hi I just seen your ad it's a long shot but do you have driverside front wing? Ta Mark
Front window prob
Hi Pete I will remove from car when next off and use your services Regards Mark
Front window prob
Sorry should of said mk1 fab vrs 2005
Front window prob
Why are my front electric windows only working in the summer!?has it anything to do with the battery under strain in winter? Any help appreciated
Air con
- Air con
Thanks will do- Air con
did a regas it's registering as normal now from empty.but it's still blowing same temp as normal Air. Can hear a change in sound when I push aircon button and more Air but not cold.any help appreciated- Caliper to hub bolt thread
Hi I'm trying to find out the helicoil size or thread repair kit I need for a front caliper to the hub .thread in hub stripped out when removing the caliper .if anyone has a link even better Ta- Front caliper thread
Hi Keith my mistake it's the large bolts for caliper to hub carrier.what size kit would I need Ta- Front caliper thread
Hi everyone the front caliper thread on my mk1 vrs has stripped.is it hard to re thread? And if so what kit do I need to use existing bolt size- Front electric windows
Where is the module located in fabia photo above motor?thanks- Front electric windows
What is the box above the window motor and where is it located ta chum- Front electric windows
Changed fuses and new front window switches in arm rest still not working help!- Front electric windows
Both windows stopped working same time if its not fuse and not window switches whats left to check ?if driverside has fault I take it it stops passenger window also?- heater fault on vagcom
v68 flap motor fault is showing on scan.Not sure what part to look for or where to purchase from or if its easy to fit.Any help appreciated as im getting cooked driving the car- Heater prob fabia vrs mk1
V68 motor flap fault showing is it easy to get and fit? Ta for the help- Heater prob fabia vrs mk1
Hi i have a v68 flap motor fault showing on vagcom.is the part easy to get and fit.thanks for your help- Heater prob fabia vrs mk1
Any ideas about my front windows both stopped working same time ?- Heater prob fabia vrs mk1
Hi i have no cool air when i turn switch in fabia vrs mk1 it stays same as if on hot any help appreciated- Windows and heater
My front windowsvstopped working also my heater control when turned does not blow cool any help appreciated- Squeal sound
Hi i tried with it with the connector off.no boosting of turbo just same as with pipe off- Squeal sound
Is it possible its the vac box on top of the strut?- Squeal sound
Disconnected vacum pipe from turbo does not make a squealing noise now under acceleration?getting confussed any help appreciated.i pulled pipe of at vac box on top of strut why is this? - Air con
