Heater prob fabia vrs mk1
Hi i have no cool air when i turn switch in fabia vrs mk1 it stays same as if on hot any help appreciated
  • Sponsor
Scan the HVAC module with VCDS and see if you have a fault code for heater flap motor.
Work the switch from hot to cold and back again a few times, the flap can get stuck.
Any ideas about my front windows both stopped working same time ?
  • Sponsor
Try charging the battery if you have or can borrow a charger. Check all cabin fuses one at a time if you haven't already.
Hi i have a v68 flap motor fault showing on vagcom.is the part easy to get and fit.thanks for your help
V68 motor flap fault showing is it easy to get and fit? Ta for the help
