Everything posted by pdrisc
- Rear Windscreen Wiper stopping mid stroke
Hi My 67 Superb has developed an issue recently with the rear wiper. It’s prone to stopping mid stroke and won’t reset unless I lift the wiper arm and twist it left and right. Then the motor will work once the steering column lever is switch on. It’s as if it can’t overcome the friction on the screen because it also appears to have slowed down in its sweeping motion. Anyone else seen this? The wiper is a couple of years old so will swap it over to see if that makes a difference.
Rear washer - poor pressure
Thanks for this input. I use a Prestone screen wash for winter at the moment. Concentrate with water from me. When its cold i add some 99% alcohol fluid but I didn't have any in this time. I think the time has come to pull the rear panel off the inside of the boot and see whats going on in there.
Morning The rear washer spray on my car seems to have low pressure. I have cleared the jets and also ran the spray without the nozzles on. Normally it would spray out about 1.5m above the car but right now its a much lower pressure. Spray height is less than 0.5m. My question is whether there is a single motor in the spray system at the bottle or is there another motor at the back of the car? The pressure at the front of the car seems fine. Or am I looking at removing the interior cover of the boot lid to see if there is a leak in there? Nothing seems to be leaking out. This seems to happen during freezing weather and once the jets unfreeze i normally have to clear the jets of "crud" but this is something new.
S3 Xenon lamp replacement guide
I changed the bulbs on my 67 L&K a 2 weekends ago knowing that I had a long drive across mid wales at night yesterday. The near side light was definitely the hardest even with the wheel and arch removed. Car was on a jack for safety. I bought a pair of nightbreakers and the improvement in light was incredible. Full beam was stretching out at least 300m on straight unlit roads. Once I realised my bulbs didn’t need to be rotated to remove it was just a case of the fiddly clips and my big hands. By the time I was finished it was quite dark which explains why I have a spare screw that I have find the correct spot for.
Radio/Touchscreen stopped working
I would recommend contacting a skoda dealer and asking them to check the firmware if you aren't able to access those details yourself. It sounds like you need to get the firmware updated. Its exactly the same problem i had years ago. That solved it.
Electric Tailgate not operating normally
Good point. Will get it sorted in next service.
Thanks Nick Thought that might be the case. Will get some ordered. Did you go with a main dealer or aftermarket supply?
Bumping this to see whether anyone has seen a similar fault and maybe missed this post.
Hello I have a 67 plate L&K and in the past month or 2 i have been getting some issues with my electric tailgate. When i press either the latch on the boot or the centre console button the tailgate lifts about 30cms and stops. I have to press the button repeatedly to get it to go up but it goes up in stages. More recently it can refuse to open at all and i have to lift it manually. The key opening is also non functioning as well. Closing seems to be fine but there are occasions when the latching mechanism is tight and the lid needs a nudge to lock into place. I have read the other threads and it looks like its probably struts but some mention a NW sensor and i wasn't sure what that was. If i get the vehicle codes what should i be looking for to diagnose the struts or any other faults?
Boot not locking down tight
Hi The boot on my L&K has developed an issue where its not clamping tight. It appears to be shut but as you drive away the lid lifts slightly and the warning symbol comes on. There used to be a clamping system on my old mk2 which played up before. Is this a similar fault or has anyone else seen this issue? Car is a 67 plate.
Speaker sizes??
The offside rear speaker on my Canton Superb has started distorting the sound badly. Car is a 67 plate so its up to me to replace it. i notice that the speakers available have different depths so does anyone know just how much space there is to play with? I want to have something better than stock but not looking to drastically upgrade the speakers as i mainly listen to voice rather than music. But similarly don't want to waste money by buying something that is too big.
- Another Question - Tow Bar or Spare Wheel
Updating Mapping
Update on this. Reloaded the sd card and started installing the update within a few mins. Took an hour to install but seems all good now.
Updating Mapping
Thanks all. i will try again. I have done everything i needed to do as suggested above so will have another go later on.
2017 hatch, Rear washer stopped working, water dripping out from boot (near camera)
sorry i forgot that you mentioned that leak. Yes it sounds like the hose has worked loose. Looks like you need to remove the internal panels. There is probably some instructions somewhere on the web on how to do it. Always remember that cars are built on moving conveyors so they should be "relatively" simple to pull apart. There is an instruction on the superb 2 forum to replace the twin door cable that is very comprehensive. I used it to fix my old car and i imagine the process will be the same on this model.
Thule Roof Rack
I have sold my Superb 2 and no longer need the foot pack that is specifically for that car. Is anyone interested in them? Not sure whether its possible to offer them for sale on the site.
Updating Mapping
I have downloaded the latest mapping from the portal to an SD card but have not been able to update the system. It won't recognise the files. The one issue i have is the instructions say i should format the card using FAT32 on the computer but my HP laptop uses a different format standard. Anyone got any tips or advice?
I had a similar issue when i picked up my 67 plate a couple of months ago. Turns out the 2 spray points were bunged up with what i can only describe as flakes of rust or dried debris. However it was easy to remedy. The plastic mount with the 2 spray holes can be removed with a flat screwdriver carefully and i used a couple of pins or needles to clear the holes. I was also able to tap out the debris that was in the space behind the 2 sprays.
Whats this in the storage compartment of the boot of my L&K
Thank you.
Was rooting around in the back of my new (to me) L&K superb. In the left hand storage compartment on the boot there is a plastic box which is ducted into the vehicle. What does it do? There is nothing in the hand book about.
Rear screen wipe and wash
@booshakker thanks for that advice. Lifted the nozzel off and cleaned it with a pin. Then knocked out all the crud and debris that was in there as well. Result is 2 clean jets now. Simple fix in the end.
Thanks for all your advice. The manual drop switch is not in the boot. I checked that after seeing the video on line. There is definitely a bracket underneath to connect the tow hitch to but as far as i can see there is no wiring visible. I did try and price a tow hitch today but skoda weren't much help. What i will do is take the money and use it to buy the spare wheel and jack set which is something i will get far better return on. I was going to look at getting a wheel anyway. If i ever need to get a tow hitch i will revisit that in the future. In thirty plus years of driving I've yet to actually tow something so chances of it happening are probably low.
I am 2 weeks into owning my new L&K car. When i saw the original advert on line the car had a tow bar fitted. However when i collected it the tow bar was missing. The dealer has been trying to source it but have now offered me £250 back instead. I don't actually have a need for a towbar (at the moment) but have no idea how much one costs to fit or replace the missing hook. I cant see any sign of electrics beneath the car so i assume the hook was a ticked option that was never fully utilised. One the other hand i may take the money and just use it to get a space saver wheel and tool kit from a local dealer. Any advice?
Cheers for this. I had a look today and there was fluid bubbling at the jets so will have a closer look tomorrow again. i did notice some rust water residual on the paintwork from when i used the washer. Sounds like thats my problem. Cheers
