225 bhp bam engine upgrade
looks like my standard octavia vrs engine has shot it (knackered oil pump)
if the engine is shot it i would like to upgrade to the 225 bam engine
i would like some help on what i need to buy eg full engine ecu and other bits
Engine (complete)
Downpipe and cats
ECU
FMIC or twin coolers (depending if using all the K04 manifolding)
Gearbox(?) If you fancy six speed
any ideas on how much the conversion would cost?
I'd say put aside £5k for everything.
ok well thats out the window then
:eek::eek::eek:
what about a straight swap for the standard engine
Depends on whos doing it and what you want.
Salvage AUQ engine about £1k all in, £800 for a local mech to fit it.
yeah, 1k for normal engine, 2k for BAM with NO extra's at all is normal.
Unless you manage to buy a Golf with an APX in it for £1500...lol
quite.
buy an engine and gearbox and get the rest of the car free!!
So i take it the engine mounting points are all in the same place?
Yeah exactly the same.
AMK is from the facelift S3 which is 210bhp and has mechanical VVT. BAM is 225bhp and electronic VVT.
I thought the AMK didn't have VVT and the BAM did. I dont know how VVT works without electronic control. AMK has the same head and cam chain tensioner as my APX.
thats bloody cheap that!!
when i was buying my engine last year they were 2k for just the block!
I've been calling around a lot lately for a s3/tt lump for my mk2. The going rate is 1500 quid for everything to do a conversion. However, I'm not 100% sure but I don't know if it would be possible to just swap most of the stuff over from the auq to the other motor and then have your ecu re-flashed with a custom map. I know some people have done this in MK4 Golfs. So I see know reason it couldn't be in there and running for around 2k ish.
Depends on which 225 engine you have BAM engines have extra sensors for exhaust gas temp and a ew other systems that the AUQ doesnt so the OEM ECU wont be able to run with them.
What's the APX?
225 bhp Audi TT engine.
What's the difference between the APX and the BAM then? Am I being thick? :)
Age, APX was out first, few revisions in software, second lambda probe, vvt and air injection added to BAM iirc. Not much.
I may stand corrected :) I just remember reading it on Audi-sport from a reputable poster..
