Intermittently Losing Power
Hi guys, Can anyone explain why my Octavia RS intermittently loses power. Going along quite nicely then suddenly a complete loss of drive. I need to pull my foot off the accelerator pedal and re-apply it to get any drive back!! could it be a turbo spool problem. Happens at all speeds and in all gears. Car was serviced recently and nothing picked up. :confused:
You might be better to have a diagnostic check carried out to see if there are any fault codes logged.
Could be something as simple as a loose connection which hopefully would be identified.
Hi Stu, Its Rod here (Lusty etc) problem happened as i was driving up to Scotland. There is no warnin lights flashing etc. When i loose power and continue to apply pressure to accelerator nothing happens. I must take my foot all the way off before i can get any drive back. Checked connections and found nothing untoward. How about an air pressure sender??
Like he said you need a diagnostic check to determine what is happening.
The problem is that if you don't have a diag check then you could keep throwing parts at it and wasting your money.
If you are going to be back in the area drop me a PM, we can meet up and I'll VAG-COM it for you.
I've sent you a PM anyway Roddy. :thumbup:
  • 4 weeks later...
Hi did you ever find out what the problem was with your car?
I am having the same problem on my Octavia.
