2.0tdi octavia
hey guys looking for help my octavia when its ticking over when cold it sounds like it has a small misfire but drives perfect any suggestions?problem number 2 is when driving along it sounds like the back window on drivers side is down i can here the wind whistling in ive tried tighting the door closer to the rubbers but it sound worse, help in these matters wud be greatly appricated
regards
david:cool:
problem number 2 may be the rear quarterlight in the rear door, there is a gap in the seal, the pain of glass can be adjusted so it sits tighter to the seal.
The slight lumpiness when cold is probally the cold start device where it runs slighty richer.I think its normal this as my 1.9TDi MK1 did this until warmed up more.
ok guys thanks for the replys
rear quaterlight whats that?
The little window in the rear door.
but how do you adjust it?
The doorcard requires removing, normally something the stealer would do under warranty.
