Help
Hi,My 2003 Octavia rear driver's side door won't open either from inside or outside.dealer wants 95quid 4 new lock stuff,scrapyard will only sell me a complete door,please help.
welcome, have you thought of just buying the door off him and offer £20 ;)
Welcome :)
Hiya.
If cost is an issue, there are lock repair kits and door wiring loom replacement kits available from dealers for way les than 95squid. Run a search for part numbers.
Hi and a very warm welcome.
You are saying that your door will not unlock.
What happens when you put the key in and turn, or will it not turn? Will it just be turning around, and doing no function?
Does the central locking, make the click noise on the bad drivers door?
I have recently had the problem of the bad drivers side lock also, and I used two Skoda repairing kits. If it is just the mechanical lock where you are putting your key that is causing the problem, then I will get the part numbers for you from my other thread that I have posted here. The total cost of the parts I remember are £1.99 for the two kits.
I can also explain how to do this also.
Soviet (I need to know more of the problem, that you have):rolleyes:
welcome to briskoda
Davy
Welcome to the forum
