Felt like a right mechanic this evening!
Well, a mechanic that is good at ripping stuff out a car.
Took this evening's good weather as an opportunity to gut out ALL the lpg gear from my car - Armed with a few tools I set about like this:
  • Jacked up the car from the middle using a trolley jack and some timber. Axle stands placed at front and back under sills. Left sat there.
  • Placed 4 carmats on road under car to lie on. Set about snipping (carefully as around brake lines) the cable ties holding the electrics & copper pipe
  • Removed, lowered and refitted the metal insert which goes across car to support exhaust? to allow lpg stuff to get off (I assume, seems superfluous to my needs - might rip it off next time)
  • Removed under steering wheel dash panel, and removed the electrics from the switchgear, taking photos and drawing diagram for re-installation
  • Had to cut some wires sadly, mainly earth ones which were out of reach. Re-attached nitrous power to the switched live I cut as had been integrated into the LPG electrics during install
  • Rerouted electrics from by driver, out behind and from under the glovebox, and through into the bulkhead
  • Wound the electrics from under the car back to the bulkhead to finally remove off my car. Included releasing a bolt holding an exhaust shield up, as the electrics was going behind it
  • Managed to bend/wiggle the copper pipework free from under the car
  • Unbolted the filler cap pipework (had to remove a rear light for spanner access), and removed filler cap from the car. Yep, you guessed it - nice 3" circular hole in my car! Can't get it fixed properly for a little while so used a section cut out of a 4 pint milk bottle and covered hole with it and double sided tape. Fingers crossed it is watertight.
  • Removed regulators from the engine bay - A sinch compared to the rest of it. Sealed up hole left in air intake pipework with tape. Need to get a new bit of pipe really....
All in all, done all the above in around 2 hours, so I was pleased as peach it went so well. Now have a box full of "stuff" and just need the lpg tank and it will all go to the new owner. :cool:
why did you remove it?
LPG is soooooo last year :rofl:
Removed due to me having race nozzles, and having adequate fuelling. Also plan to try methanol/water injection.
PS KTP - I need your help very soon. ;) Will draft out a PM at some point this evening. :D
Here's two pics of holes in my car. :D All good fun in the world of mongrelling.
Hole in the side of my car. :eek:
Hole in my boot floor. :rofl:
Is this a new Mongrel thing Jason - a rear light cluster, sans lenses, installed in the wheel well? It looks cool, but I'd question its functionality.
The light unit was refitted along with the cluster later on?! :P :rolleyes::D
Anway, both sides are coming out tomorrow morning as I go to collect my facelift clusters from the post office. :cool:
You can buy Fabia light clusters in the Post Office now :rofl::rofl:
Sorry couldn,t resist that one.
I didn't think you could LPG convert a diesel car? Or am I missing something here?
yes you can, its done to clean the burn rather than run on lpg.
Or in my case, provide too much fuel and create a smoke hazard, hence it going. Well, here's some photos from today.
Complete powershot propane kit! :rofl: (sold ;))
The facelift clusters fitted. I do like them. :cool:
And my very temporary LPG filler cap hole cover-up! :rofl: Is likely to be on there for North Weald which might prove to be a source of amusement
