Electrical/Wire Map
Has anyone got a map of all the wires in a P reg skoda Felicia 1.3GLI?
The reason is because my dash light and rear RHS light are out, when I replaced the fuse it blew again and I've also changed the bulbs.
I believe it to be a wiring fault and want to try an rectify it without taking it down the garage.
Haynes manual should have a wiring diagram. But the cheaper option is to open the panel as if to change the bulb and follow wire from rear right hand side - should be easy to see what colour wires it connects to at the block connectors (may be different to the wire leading to it) and follow this to the fuse box by removing the kick and trim panels. There is only one wire as it earths out at the light unit.
I am also having a similar annoying problem currently :( so you're not alone.
Thanks, I'm gonna have a crack at it in the morning before work and see what I can do. :thumbup:
FYI the wiring loom for the rear lights runs down the left hand side of the car
