Hello, I am in the dark.
Hello,
coming from a generation where to take a car overseas all you had to do was tape over a clearly defined triangle on the headlamp lens, I am at a bit of a loss as to the easiest way to flatten out the dipped beams on my 2007 Roomster Scout.
Are there any stick ons? or is a headlamp bulb change required?
Personally, I just turned the lights down to the lowest setting.
Welcome to the site :)
Thanks for that, usually the simplest option is the best.
welcome
welcome to briskoda
In addition, at dusk, park where you can get the lights shining on a wall / garage door. You'll be able to see the light pattern on the wall. Then use a piece of card over the lens to work out which bit you need to mask off (ie the bit where it goes up and left). Then use your tape.
