Applying Vinyls?
Whats best?
Water or Hinge?
Oh its a full length of a car one by the way!
Soapy water and lots and lots of patience
If it's the full length then I'd suggest using a spray using a mixture of water and a small drop of washing up liquid or similar. Apply liberally to the 'sticky' side and a little to the area on the car then align and squeegy out any bubbles. A hairdryer may help you mould round difficult angles in bodywork.
If it's the type of vinyl with a backing sheet this is better applied dry but will need a steady hand and is easier if pre aligned with masking tape.
Anyway enough advice from a mere novice, try KTP (Keith) for an expert opinion :thumbup:
What kind of 'sticky' are you applying?
Oooh nearly forgot, get yourself a VERY sharp blade like a craft knife and use the contours of the bodywork as a guide for your hand/fingers to trim accordingly.
Its the Greenline decals on a Fabia Greenline!
So speaks the Viper Stripes Master ;)
I'm an expert don't ya know :D.................................. want yours doing Mark? :P
Much as I liked the ones you have more than the silver ones you had, I'll take a raincheck on that :thumbup:
Should sell them as stone chip protectors mate :D
