Vibrations
I have an 2007 Octavia 1.9 Eligance DSG and i am getting vibrations at 1200 rpm,
my local suppllier said it was the flywheel and has replaced it, but we still have the vibes,
has anyone had or know of this problem
Hi,
Had the same problem, noise was coming from the passenger side behind the glove box at high level. Mine was at about 1400rpm and turned out to be some kind of loose cage or something behind the dash. Took the garage forever to find but its fine now!
Hope this helps.
Had the same problem, turned out to be the DMF but god knows how many different driveshafts were replaced before they found out it was that causing the problem.
I have vibrations/judder and i know its the DMF but will get it changed when it becomes severe.
Hi,
Hope this helps.
Thanks, that sounds like the noise i am getting it will take for ever to find it
