Fabia air con question
Hi all,
After reading threads on air con for the Fabia I have come to the conclusion that if the vapour sensor is faulty then the air con should work for a short period before it stops doing so. If there is no air con or only a drop of a couple of degrees (measured) the a recharge is probably required. Is this a reasonable conclusion assuming no other faults be present? By the way does the Elegance 1.9 diesel estate have wear sensor(s) on the rear brake pads?
Thanks for reading,
Peter.
No Fabia in the UK has wear sensors on any brake pads front or rear.
Depends whats wrong with the evaporator sensor, they can fail and cut the AC out permanently.
Thanks for clarification.
