MFD2 Cor D?
Which version would you go for if you were buying one?
And whats the basic difference between c and d?
Thanx in advance.:thumbup:
I didn't think there was a version for the Skoda MFD2.
There is for VW though.
Just checked flebay, and the c and d versions are VW. Thanx hedge.
If you only want a UK map, and green lighting then get the proper skoda one. You can get other countries but will need to change the CD as you navigate in each one.
If you want a full european map on a single disk, then get a later VW one with DVD drive, you will however end up with blue lighting.
Oddly the DVD based VW one will be cheaper than the skoda CD one because its more common.
Thanx mannyo.
