Oil in SMIC?? Should I worry?
hi lads n ladets,
I have just replaced my SMIC with the Forge FMIC (b4stard to fit but now it on looks ACE:thumbup:)
When I was takin the old one off I noticed quite a bit of oil in the pipe work and in the IC(it ran out onto the drive 1.5" diam of both patches.)there was enough to smear all over all the bolts n screws. There was an aufull lot and am just wonderin if it is somethin to worry about?
the car has 48+K on the clock all by me and I have noticed oil in the pipes B4 when i swapped the DV and pipe plus the pipe to the manifold at about 42K(there wasnt as much as this time)
the car has had 2 Skoda Dealership services, first one they put the 0w 30 back in and the second about a yr ago they put 5W 40??? or 5W30 one or tuther.
the oil was lookin a bit dark and it is 6k off its next service(ish) so I took it upon myself to use the MT ramps and change the oil filter and oil.(0W 30)
I felt that the car ran better on 0W 30 so I put that oil back in, now I have this problem? if it is a problem?
What do you guys think?
sorry its so long, hope you can understand it all,:P
cheers for any info
billy:thumbup:
No.
See elephant mod in technical guides if it worries you.
ive jus read the first few lines and I think I know y skoda switched to a thicker oil?
so that there is not as much vapour there for less emitions?
oh well
if that is the fact then that could explain y the build up has got so much in the last few month.
my oil level hasnt gone down though????
oh well
Not to worry mate - oil in the FMIC is a "design feature" - "they all do that" :rofl:
after a while wont it build up in the bottom of the FMIC?
Spose Ill have to drain it after 30-40K?
cheers
It ends up coating the throttle body and we all have to clean it off after a while to prevent the hesitation :mad:
mmm
now i have some hesitation.
my TB looks clean? or is it the side that you cant see that gets dirty?
No its the side you can see iirc.
good good
cheers mate
oh n what does iirc mean?
If i remember correctly
r g r k
cheers:O:rofl:
