drivers door connector replacement
I have replaced the circuit board inside the drivers door that is connected to the window motor. During re assembly i have noticed that the female side of the connector which plugs into the bottom of it is damaged. Is it possible to replace this bit? Do you have to renew the whole door loom or more? Any help would be much appreciated. thanks.
:bump:
