need help with gear oil
Hi all
Does anyone knows which gear oil to use for my fabia 1.2 47kw. Gear code is GSB 9102 /5 speed manual. I have Statoil Gearway PS45 oil 75W90 (Semi synthetic) which is conforming to API GL-4/GL-5 ! is that appropriate oil? or should it be fully synthetic? Is it going to cause any damage if used? thanks a lot...:confused:
I would have thought a semi synth 75/90 would be fine to use.
You've got the right one.(75w90 semi synth api gl4)
thanks a lot for the info
