help please
hi i've run vag-com on my car as its running rough (hunting idle and low power)
and got this fault code read-out but doesn't overly help :(
00537 - Lambda (Oxygen Sensor) Regulation
19-00 - Lower Limit
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
31-10 - Open or Short to Ground - Intermittent
so can someone help please
Try disconnecting the MAF, and see if the running improves.
Also try checking the voltage across the lambda on a hot engine, lookin for about 0.7V IIRC.
