Engine management Help
I have just had an oil pressure problem sorted out, and today the engine management light has come on again?
code: 17544
Fuel Trim Bank 1 - system to lean
This points at many possible issues
Fuel pressure / pump
Injectors
Intake / exhaust leak
Air system
Hose leak
has anyone had this problem? as this code keeps returning after the light has been put out and we cannot see anything obviously wrong
Most liekly to be a split hose causing an air leak. CHeck all the hoses, particularly the one that runs infront of the engine, just to the right of the dipstick. You may have to remove the black metal plate through which, the dipstick passes to do this.
I'd agree with Goochie on that. Carefully manipulate the breather hoses with the engine running and listen out for a hiss as the air gets sucked in.
Will do in the morning - Cheers
