Skoda Touch up kit
I just bought an official touch up kit from Skoda, its the official one and you get the paint stick along with a lacquer pen.
Does anyone know what the lacquer pen is for? Is it to be used after the paint stick as a finish off seal?
Some advice would be appreciated.
Yes, metallic paint has a satin finish and the glossy shine is obtained with a clear lacquer over the top.
Wait for the colour to dry and then apply the lacquer over the top.
The colour one is a base coat then lacquer over the top.
Another way to do it is to mix a little of each then apply. Don't use the brush provided as you'll end up with too much paint. If you can find a very fine brush that should be o.k but I tend to use a tooth pick.
HTH.
That's great! Thanks for your advice guys. The toothpick definately helps I just tried it out on a couple of stone chips.
Thanks again
