2001 Reg 1.4 16v Fabia- EGR Problems
Hi All,
I brought my car 3 months ago and within the last month everything seems to going wrong.
I have both the EPC and Engine light on. Whilst the car runs well once started, it seems thirsty and won't start first time (5/10 times). I work remotely and this makes me nervous.
On its last trip to the garage the mechanic cleaned the throttle valve & casing which was choked with oil and cleared all my error codes.
The engine management light has now returned and the mechanic is suggesting that i have a new EGR valve.
Essentially my query is whether the EGR valve can be responsible for the car failing to start on a regular basis (it does always start after 4 or 5 attempts). Once started the revs appear to flutter and then settle, this can happen at the start, middle or end of a journey with no continuity.
Having low funds for any repaire work i am worried that fixing the EGR valve will not sort out my starting problem.
The mechanic has indicated that the EGR alone will cost £137.
Any advice on this is extremely welcome
Bev
2001 is a Fabia I not the II
Back to topic I found what I was looking for in a prev thread
My Cousin has a Fabia 1.416v (2003 mdel)
Engine management light came on with the EPC light. Had the throttle valve cleaned and the computer reset but after nearly 2 weeks the fault light came back on.
actual fault was temperature sensor.
Now changed and the car is running better than ever and geting 40mpg+
Edited by Captain Sisko
Has the car had the piston rings changed, all your quirks point to this?
Roger.
What are the fault codes?, I have known replacement temperature sensors to cure starting problems on these engines, even when the originals do not show a faut. They show implausible values when the engine warm up temperature readings are logged.
Where did you live?, as quite a few people on here could read your fault codes for you.
Roger
(Do not give too much info!!!)
Thanks for replying to my post and apologies for putting it on the wrong fabia section!!
I will post my error codes when i get home to see if that helps.
Bev
(Currently in denial and tempted to put duct tape over my EM light :P)
