bushes
whitch one bushes from a other can can fit to octavia
from golf r32 auti or seat
powerflex i can t get at my country
Can you be a little more specific, are you after poly bushes or standard bush's?
Also what bush or are you after? wishbone, anti rollbar, rear beam or dogbone?
MK 4 golf share's the same bush's as the octavia with a few variations for arb due to different thickness's and wishbones depending on whether they are pressed steel or moulded iirc
im after better one from audi tt or golf r32
i thing they are better then orignal skoda
but do not konw if they fit or they partnumbers
Are you afer all the bushes?
the standard bushes are all the same iirc wether you get them from audi skoda seat or vw.
superPRO bushes are not bad, same as Powerflex,
say which you are after adn the country you are in? maybe someone will be able to help.
Audi TT (at least some do) uses a better wishbone rear bush, it doesn't have the voids in like the VW/Skoda ones - sorry not sure of exact part numbers, but they are interchangeable.
*edit* ahh.. found this, may be helpful - Suspension Bushes 2WD - uk-mkivs
thats all i wanter to konw many thanks richm
