Windows
Hi, i have full electric windows in my fabia 2000, but none of them work apart from the driver side console.
anyone encountered this problem?
It might just be the convenience unit that's gone funny. Look in the manual for the correct fuse, pull it out for 10 seconds or so, put it back in and see if anything changes. If so, you will have to reset the one-touch function by holding the lever in the up position until the windows reach the top and you hear the motor 'relax'.
HTH
i will check the fuse and try the one touch reset but the only thing is, if im doing it from the drivers side console, will the windows then work from the drivers side. thanks.
