1.8t injector issue
Hi, I wonder if you can help. I believe I have an intermittant problem with a single petrol injector. Sometimes the car runs normally and sometimes it only runs on 3 cylinders. I know which one it is and I have swapped plugs and coil packs to eliminate them. The same cylinder continues to be a problem. IS there an OEM injector I can buy or do I have to spend £100 on a new injector?
I have removed the injector and cleaned what I can. When I had the injector out if I hit it into my hand petrol seeped out and for a while it ran fine perhaps 90 miles without a problem, then it is intermittent again.
I also tried an injector cleaner in the fuel.
Any help appreciated.
Spec KS 110KW AGU '99 model.
Shame mate, I sold my 4 OEM injectors not so long back.... £30 they went fo I think.....
Give Jabbasport a call (01733 211779 - ask for Nick) they do injector servicing IIRC
Steve:)
Many thanks Steevie, I spoke to Nick, he doubted that it was the injector. I will swap two injectors over to see if the fault follows the injector (on his advice) If it doesn't than I have a slightly more serious problem.
With it running on three identify which cylinder it is and check compressions
:iagree: - if it's not the HT, check for a wet plug, because injectors rarely underfuel if they fail. If there's not a wet plug, do a compression test next.
Well, in desperation I eventually took the car to my local VW dealer. They ran a diagnostics which highlighted the injector, however instead of changing the injector they disconnected and reconnected the MAF. This wa something they had done in the past with V dubs and it works. It may not be a permenant solution but it has fixed my problem for now. Many thanks to all who tried to assist or showed an interest. I hope this post will be of some use.
Glad you got is sorted:thumbup:
