Oil Leak..from cooler pipe ?
Hi all,
I have noticed a couple of small oil drops in the drive from my 2005 Fabia vRS, I have looked underneath and if you look on the drivers side underneath the engine cover there is a join where this meets the wheel arch cover. Where it joins there is a small gap and a sort of ribbed pipe (light grey i think) is showing which is where the leak is from. I have seperated the two bits of plastic (arch liner and engine cover) and tried to see what this part is and it seems to be part of a 2 inch bore black plastic pipe which I presume would be to the oil cooler.
As you can tell I am not very mechanically minded and have just taken an educated guess, anyone any ideas....is it just a case maybe of tightening something up ?
Thats the intercooler.
Bit of oil is perfectly normal
