Front ARB?
Am i right in thinking that the front ARB from a FUN will fit a normal felicia?
And if so where might one get hold of them these days as Butts of bawtry no longer stock skoda parts!
Phil
Should do, the roll bars are the same on pretty much all felicia's, the fun ones are just 22mm as apposed to 20mm the only thing you may have to do is change the d bushes as well, Skoda dealer prices are:
Bar 6U7411309 £63.85.
Bushes 6U7411314 x2 £4.08each.
Hope this helps.
the fun has a 20mm bar:) but it will fit
here's a pic of the 22mm bar, these ones are only available from vw commercial vehicle dealers because it's normally only fitted to the caddy pick-up..
the only problem you might have phil is that some of the 1300 felicia's don't have the holes in the subframe to take the anti-roll bar mounting
Here's a thread of someone fitting one to a fav. Board Message apparently you might be able to drill the front subframe (if needed), and get the nuts and bolts through, without removing it from the car.
that link dont work :o
oh yeah.... also your track control arms may not have holes in them to accept the droplink either
Here's the pics from that link anyway
very nice.... i've seen those pic before somehwere... nylon track control arm bushes :rubchin: i think that might be a member on here
Their username is ken over on skoda-forum.com
nylon bushes hay!!!!!!!!!!!!!!!!!
want me some of them.
yeah, nylon is really easy to machine too :rubchin:
go on tom, you know you want to!!!!!!!!!!!
oh dear i feel another 'project' coming on :D
