AAt strut braces
For those that missed in on scn have had the lower front and rear stut braces from aat fitted. Front about 1 hours work as the wishbone slipped! The back envolved dropping the rear axle and suspesion so 3 hours!!!
1796.attach
:eek:
But how does it drive?
Nice and taught and not to bouncy over the bumps. Although I think if the car was running stiff suspension it might be a bit too harsh. Interestingly it seems to have helped with grip with the car seems less likely to use esr if you boot and turn at a junction.
Looks good, but it's a bit of a problem if you use the boot ;) Is there a rear-lower strut brace which has the same effect but sits outside of the boot? :) Alternatively, can anyone recommend a thicker ARB for the Fabia which will reduce the body roll a bit more?
Chris
I'm thinking of going for the H&R arb in the not to distant future..... Thats if I dont decide to do the exhaust! Know what you mean about the boot, sits about 1.5 inches off the boot floor and am now having a right job to fit in swmbo's wheelchair!!!
