Camber on front wheels?
how can i sort the scrubbing out of inside front tyres!
after now having 18's on it and coilovers, effecting tyres really badly!
Wide-Arch mod? Roll the arches? Wind the coilovers up?
Not sure if you can change the camber on the fronts. And if you can then it'd probably drive like a pig and wear the tyres down uneven?
yea cos iv got them wound right down now and looks amazing but dnt want to lose that look just need 2 stop wearing the inside edge away!
Kw do a topmount camber kit contact jabba sport they will sort you out
Ahh, thought you meant the other way; Wouldn't you have rubbing issues with the arch if you reduced negative camber on 18's and 'as-low-as-it-goes' coilovers though?
Mine wear out slightly on the In side but that's wat happens when you lower a car by alot
going too low is bad!!!
bad i tell ya!
It'll probs be more "TOE" thats making your tyres scrub on the inside than camber.
Get a wheel alignment done.
After fitting my coilovers the scrubbing on the inside edge of my tyres was bad.
did u have an alignment and did that solve the problem?
Oh bummer lol.....
If you havent had your wheels aligned after fitting the coilovers it will be the toe that is wearing your tyres, lowering the car wont effect camber enough to wear the tyres, as the strut is still in the same plane as what it is as standard!
but lowering will cause toe out on the front wheels which will scrub tyres.
HTH
Luke
i had the alignment done when the coilovers were fitted by APS in Brackley, Oxford.
Thanks Jabba, Need to be in touch with you guys actually im after those green jabba stickers we spoke about.
Also thanks again for my Clutch, Flywheel, etc fitment!! Going GREAT!
