Increase Trip Computer Accuracy?
I went on a long drive to Wakefield a few days ago. My MPG on the trip computer was recorded as 72MPG.
Now when i finished my journey, 440miles later I filled up and worked out my MPG which came out as 53MPG.
Now I know the computer lies, but i sat on the motorway and didn't stop. almost 20MPG out is alot.
I was wondering if there is a way with VAGCOM to adjust its accuracy?
I found this:
Controller adjustment
STG 17 (combination instrument) select
STG adjustment - > function 10
- > channel 30 (tank fuel sensor adjustment)
The default value is 128, adjustable in 1 ohm steps (range 120 - 136).
But when I try to read channel 30 I get an error so I'm not sure this valid :/
  • 4 weeks later...
Is that how the trip MPG calculation works then? Via the tank sensor?
I'm not sure, but I'm giving it a try. I have set it to 120ohm and have started on a full tank so I'll see what the real MPG is to the computer MPG. I'd be happy if it was only just 5MPG out.
There's a thread on how to do this - 'Useful VAG-COM Codes' or something. Depending on the age of your car, it may not be completely current, but it'll be a good start! :thumbup:
Then again, most people reckon about 10% out, so your readings are a bit extreme... :ne_nau:
I did have a look but couldn't see anything. The only other option is channel 03 for accuracy which you can modify (85% to 115%). Unfortunately this channel is non existent on my '06 VRS :/
